Thread: Rattle on drivers front side
Results 1 to 9 of 9
  1. #1 Rattle on drivers front side
    rochester, ny
    I got a 05' GP, been having knocking/rattling noises from the front for the last few months. It isn't the tie rods, sway bars, sway bar links, ball joints, loose wires or engine cover, I looked this thing up and down and it doesn't seem to be any one of these issues. Anyone know what else it could possibly be? Kind of tired of hearing this noise over and over again. Who has an idea as to what this might be?
  2. #2 Re: Rattle on drivers front side
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    motor or tranny mount...when does it make the noise? on bumps, when turning, in reverse. i see that your new hear..hello...next time u post add as much information about your problem as possible and youll get more results and we will all have an easier time helping you
  3. #3 Re: Rattle on drivers front side
    rochester, ny
    only happens when there are bumps, it's not really noticeable when driving at higher rates of speed, only at lower rates of speed. If i am driving over some smaller bumps or divets in the road that is when I can hear the noise. I've had it since I owned the car, and it's driving me nuts to be honest
  4. #4 Re: Rattle on drivers front side
    Feb 2010
    somewhere cold
    could be a strut too...kinda hard to diagnose over a computer with limited info
  5. #5 Re: Rattle on drivers front side
    SE Level Member RideMr2's Avatar
    Memphis
    This sounds like the intermediate shaft to me, it is a very common problem.
    Use google, type in intermediate shaft.
  6. #6 Re: Rattle on drivers front side
    vermont
    Will almost guarantee it's your sway bar end links. I'm on my third set. If they are under load you will not be able to tell. Just slide under the car with the suspension loaded and bang on the bottom under the end links. They will probably rattle. Moog makes a beefier one but the sockets still don't hold up long term. Plus side...they come off easy when you need to change them.
  7. #7 Re: Rattle on drivers front side
    Indiana
    Mine rattles real bad over bumps or a rough road front driver side too. I have a 97 gtp any ideas it really makes my car sound like a clunker.
    1997 Pontiac Grand Prix GTP SUPERCHARGED Black with Blackouts
    1996 Pontiac Bonneville Under Construction. Soon to be supercharged along with a little extra :P
  8. #8 Re: Rattle on drivers front side
    vermont
    The intermediate shaft noise on mine (2004 GT2) was different. It rattled when you turned, even on smooth surfaces and low speeds. The sound was consistent in each direction.
    The end links sound more like someone wrapping on your front suspension with a small hammer, worse at lower speeds and smaller road imperfections. I am seriously considering changing my lower control arms to the older style and putting on the older beefier sway bar and links. Seems like it's a direct bolt on according to some other forum posts. If so, problem solved and better handling.
    On my 97 Regal the banging was the end of the sway bar had broken off. Some replacements are solid unlike the original.
  9. #9 Re: Rattle on drivers front side
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I had a rattle on my '98 that turned out to be a missing screw that went into the front bumper cover. found it by accident when I snacked the bumper cover while washing the car. might be worth knocking the plastic around on your front end?
  1. drivers side CV shaft
    By Jakegday in forum General Tech Discussion
    Last Post: 07-03-2010, 05:42 PM
  2. drivers side axle
    By planogtp in forum General Tech Discussion
    Last Post: 12-22-2009, 07:50 PM
  3. GTP drivers side axle?!?!! HELP!
    Last Post: 12-20-2009, 11:52 PM
  4. front end squeaking/metallic noise on drivers side
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 07:36 PM
  5. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
