Do you have a way to support the engine/trans from above? If not, this works great:
1000 Lb. Capacity Engine Support Bar
I run a wire from the engine support down around the steering shaft to keep it it place. There is also one or two screws you have to remove that hold the power steering lines to the cradle.
The cradle is not that heavy, but it helps to lower it easier with a jack or two. A rolling transmission jack works great. Put a big rug, like a moving rug, under the cradle, and after it is on the ground, you can drag it out from under the car with the rug.
