Thread: Brake Rotor Question
Results 1 to 11 of 11
SNeitzel Brake Rotor Question 09-30-2010, 11:18 AM
matt5112 Re: Brake Rotor Question 09-30-2010, 11:27 AM
SNeitzel Re: Brake Rotor Question 09-30-2010, 04:21 PM
Bio248 Re: Brake Rotor Question 09-30-2010, 12:10 PM
SNeitzel Re: Brake Rotor Question 09-30-2010, 04:13 PM
Bio248 Re: Brake Rotor Question 09-30-2010, 04:14 PM
gtpinsc Re: Brake Rotor Question 09-30-2010, 04:45 PM
Warhellride Re: Brake Rotor Question 09-30-2010, 07:51 PM
matt5112 Re: Brake Rotor Question 09-30-2010, 08:30 PM
SNeitzel Re: Brake Rotor Question 10-01-2010, 09:20 AM
QUICKSILVER462 Re: Brake Rotor Question 10-01-2010, 12:21 PM
  1. #1 Brake Rotor Question
    S Texas
    I have a question about drilled/slotted brake rotors.
    When installed, which direction should the slot be going?
    Should they sweep forward or backwards?
    I have looked at many pictures online of different cars and there seems to be a 50/50 split as to how they are installed.
    Does it even matter?
    Thanks.
    2004 GTP COMP-G
  2. #2 Re: Brake Rotor Question
    Slotted rotors are sold as side specific.
    So if you order a pair, you'll have to order one right and one left.
    Couldnt tell you which way though.
  3. #3 Re: Brake Rotor Question
    S Texas
    They were sold as a pair but when they came both have the same part number on the box and are not labeled. They are definitely different however. I have contacted the company I bought them from already but thought I'd check here for an answer as well.
    EDIT:
    I checked and actually they were not sold as a pair.
    I ordered 2 front rotors and they sent the correct items.
    2004 GTP COMP-G
  4. #4 Re: Brake Rotor Question
    pretty sure the outer most part of the slot hits the pads before the inner part.
  5. #5 Re: Brake Rotor Question
    S Texas
    This should help.
    Which image is correct?
    Image 1:
    or
    Image 2:
    2004 GTP COMP-G
  6. #6 Re: Brake Rotor Question
    image 2 is how i think they go, but ive never owned a set.
  7. #7 Re: Brake Rotor Question
    Jul 2008
    sumter,south carolina
    2nd pic is correct... i ordered powerslots and thats how they said to put them on... they also said if u like the look of them the other way... its fine to do so it will not hurt them.
    02 GTP with mods 05 GP for DD
  8. #8 Re: Brake Rotor Question
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Click me for an explanation with pictures.
    What matters isn't the direction of the slots on the outside of the rotor, but the direction of the cooling vanes on the inside of the rotor. The cooling vanes inside the rotor should sweep back like the slots in the first picture. If your rotor has straight vanes, then it can be mounted either way.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  9. #9 Re: Brake Rotor Question
    stoptech is awesome.
  10. #10 Re: Brake Rotor Question
    S Texas
    Got an email back from Rotorwork...
    "...the rotors are universal you can install them anyway you like depending on the style that you like..."
    Nice link Warhellride, lots of good info. I'll check mine and see if they are vented a specific way but if rotorwork says they are universal I'm guessing not.
    I also got this explanation over on the F-Body board from Joe 1320:
    "They should be installed as in pic #1. The reason is so that the slots evacuate dust, debris, water and sweep it outward rather than channeling it toward the hub."
    That makes perfect sense.
    Thanks everyone for your help.
    2004 GTP COMP-G
  11. #11 Re: Brake Rotor Question
    HUDSON
    I think the air exit (top of rotor) should always be trailing the direction of rotation (top pic).
  1. Brake pads/rotor help!?
    By Boostin98 in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2010, 05:33 PM
  2. Rotor Question
    By kjclawson in forum Brakes/Suspension/Chassis
    Last Post: 08-02-2010, 08:32 PM
  3. brake rotor.
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2009, 02:32 PM
  4. e-brake rubbing inside of rotor
    By popeyenate in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2009, 12:08 AM
  5. R1 Concepts Brake Rotor Install
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 07-01-2008, 08:47 PM
