Thread: If its not the alternator, what is it?
Results 1 to 9 of 9
  1. #1 If its not the alternator, what is it?
    New York
    i have an 02 gp 3.1.. my cars been acting wierd, the dashboard lights / radio will shut off and come back on like i lost a quick connection.. the battery light comes on and goes off as it pleases, we checked the battery while it was running and it said it was getting no charge so i replaced the alternator and it still says no charge.. what else could it be? and where should i check for shorts?
  2. #2 Re: If its not the alternator, what is it?
    Pennsylvania
    Bad ground
    Bad battery
  3. #3 Re: If its not the alternator, what is it?
    Nova Scotia
    I'm with slow on the bad ground.... check to make sure the ground wire is connecting to the neg post on the battery... i've have a problem with the rubber boot on the neg sidepost....when u tighten the sidepost bolt it wont tighten the ground flange to the battery like it should... i just used a washer to fill the gap and conduct properly
  4. #4 Re: If its not the alternator, what is it?
    Akron Ohio
    check the fuse in the motor bay its called alt. sense, then check the wire from the starter to the alt.
  5. #5 Re: If its not the alternator, what is it?
    bad battery
  6. #6 Re: If its not the alternator, what is it?
    Apr 2009
    stockton ca
    its the flux capacitor fluxin
  7. #7 Re: If its not the alternator, what is it?
    Willoughby, Ohio
    torque nailed it!
    also check the ground on the chassis too, it should be tight and clear of any rust/debris
  8. #8 Re: If its not the alternator, what is it?
    New York
    Thanks guys it turned out to be the battery was shot.. i didn't think a bad battery would mess everything up like it did..
  9. #9 Re: If its not the alternator, what is it?
    Willoughby, Ohio
    glad you found the problem, now enjoy the GP
  1. Alternator?
    By Vagen in forum General Tech Discussion
    Last Post: 08-24-2009, 12:05 AM
  2. Do I need a new alternator?
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 09:23 AM
  3. HO Alternator
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 08:48 PM
  4. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  5. is it my alternator?
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:38 PM
