Thread: misfire?
Results 1 to 6 of 6
  1. #1 misfire?
    detroit
    Thinking about buying a 2000 gtp but it has a misfire? the guys works on cars and says he think its "i dont kno 100% but im thinkin control modual under the coil packs. its something minor" does that sound right and the check engine light isnt even on?
  2. #2 Re: misfire?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    A misfire could be a Ignition control module sure. It could be plugs, could be wires, could be alot of things. So its hard to blindly say whats causing a misfire
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: misfire?
    detroit
    It's has new wires, new plugs and new coil packs as of last month so ignition control module? And how much do they run
  4. #4 Re: misfire?
    Hagerstown,Md
  5. #5 Re: misfire?
    Hagerstown,Md
    I would personally take out the module and get it tested. As you can see there not cheap
  6. #6 Re: misfire?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    and what kinda miss...not very often do these go bad and when the do they tend to miss at specific times or not work at all....also what is the car doing exactly. we all took for granted that u actually diagnosed a misfire as a misfire. give as specific account as possible of what the car does and if it changes under load and at different rpms
  1. HELP PLEASE! Misfire at 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2013, 05:34 PM
  2. Very Bad Misfire
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-12-2010, 09:17 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. 99 GT Misfire on cyl 6.
    By mazzafamily in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2009, 10:12 AM
  5. 97 GTP Misfire
    By ThePrimerSuspect in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 10:42 AM
