if its holding at 40psi then it cant be and injector if u press the gas peddle does it start as this would signify a bad idle air control valve
It will try to start, but will not keep running. Even after I turn the key on twice and let the fuel pump run, I have to crank through the first pop of it trying to start and i will then start once the starter grabs again. Where is the idle air control valve?
