Thread: fuel system?
Results 1 to 12 of 12
  1. #1 Re: fuel system?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by iluvbst View Post
    ok so what your saying it doesnt raise the fuel pressure...Cause im asking about is fuel pressure to see if my system is working properly...cause if i bypass the resistor, fuel should change shouldnt it?
    You should have 42psi regardless of pump speed at idle under vacuum
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: fuel system?
    SE Level Member iluvbst's Avatar
    kissimmee,fl
    Ok so all I needed to know was does it effect pressure...because from what I read everyone makes it out as if that's what it does. And no need for the link..as I said before, I have plenty of experience with cars, just not gtps....the whole reason I come to this forum. Thanks for the feedback.
  3. #3 Re: fuel system?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    if u did u would know that any fuel pressure regulator will keep a constant pressure unless the fuel pressure went rediculiously above norm or below regulator setpoint...u knew the answer already if your above statement is true...second who is the everyone u refer to as everyone has been stating the opposite
  1. Anyone know what this part is? Fuel system..
    By cbeebe1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:07 PM
  2. My new fuel system...
    By Hellfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 10:37 PM
  3. '94/'04 swap -- Fuel system
    By Orbital431 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 01:52 PM
  4. Fuel System
    By joesforspeed in forum Turbo
    Last Post: 02-04-2009, 12:38 PM
