Thread: Ideal timing
Results 1 to 20 of 31
01gpgt01 Ideal timing 09-20-2010, 02:42 PM
matt5112 Re: Ideal timing 09-20-2010, 03:24 PM
Bio248 Re: Ideal timing 09-20-2010, 04:14 PM
cerick08GP Re: Ideal timing 09-20-2010, 04:51 PM
01gpgt01 Re: Ideal timing 09-20-2010, 06:41 PM
01gpgt01 Re: Ideal timing 09-20-2010, 06:45 PM
Bio248 Re: Ideal timing 09-20-2010, 07:01 PM
01gpgt01 Re: Ideal timing 09-20-2010, 10:54 PM
Bio248 Re: Ideal timing 09-20-2010, 10:56 PM
copperpacecar Re: Ideal timing 09-22-2010, 09:34 PM
matt5112 Re: Ideal timing 09-22-2010, 09:48 PM
copperpacecar Re: Ideal timing 09-23-2010, 10:00 PM
FoSHO99 Re: Ideal timing 09-23-2010, 10:20 PM
matt5112 Re: Ideal timing 09-23-2010, 10:22 PM
FoSHO99 Re: Ideal timing 09-23-2010, 11:37 PM
blueguy Re: Ideal timing 09-23-2010, 11:51 PM
01gpgt01 Re: Ideal timing 09-24-2010, 09:28 AM
Bio248 Re: Ideal timing 09-24-2010, 08:00 AM
matt5112 Re: Ideal timing 09-24-2010, 10:57 AM
FoSHO99 Re: Ideal timing 09-24-2010, 05:50 PM
01gpgt01 Re: Ideal timing 09-24-2010, 06:00 PM
copperpacecar Re: Ideal timing 09-25-2010, 09:36 AM
matt5112 Re: Ideal timing 09-25-2010, 08:12 PM
copperpacecar Re: Ideal timing 09-26-2010, 03:30 PM
GAFF Re: Ideal timing 09-26-2010, 10:37 AM
copperpacecar Re: Ideal timing 09-26-2010, 03:19 PM
copperpacecar Re: Ideal timing 09-25-2010, 09:43 AM
Bio248 Re: Ideal timing 09-25-2010, 01:38 PM
FoSHO99 Re: Ideal timing 09-26-2010, 09:00 AM
copperpacecar Re: Ideal timing 09-26-2010, 03:17 PM
TheOtherNick Re: Ideal timing 09-25-2010, 01:55 PM
  1. #1 Ideal timing
    Hagerstown,Md
    So im sitting at 20 WOT now on a 3.6. I went up from a 3.4 pulley do to high track times (14.0@99 mph 2.1 60ft) so I figured id give this a shot. Where would you stop at? 21 wot?
  2. #2 Re: Ideal timing
    Tuning Your Timing Tables - OpenTuner Notebook
    someone will say 16* and the smallest pulley you can get away with. Most torque that way.
    Someone will say 18* and the smallest pulley you can get away with. Better balance of torque, horsepower, and SAFETY in the case of knock.
    And the link i sent you says 20-21. Most power, smallest safety net.
    How agressive do you want your tune to be?
  3. #3 Re: Ideal timing
    heres what i say:
    - if youre gonna beat on your car a lot, run 16* WOT
    - if youre gonna beat on it, but scan it a lot and pay attention, run 18* WOT
    - if youre gonna scan a lot and always pay attention, run 20* WOT
    this way you can romp on it a lot and not care because your running lower timing.
  4. #4 Re: Ideal timing
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by 01gpgt01 View Post
    Just some friendly advice for what it is worth. You might be going the wrong way for maximum power. I'm saying might, not that you are. Advancing timing until KR, then backing off isn't good tuning IMHO. If in fact that is what you had planned. Also more timing doesn’t always mean more power. You could street/track tune if you are a good consistent driver and just use tracks times as the HP indicator. But really you should consider some dyno time. Not to bash any particular boxed tunes out there, but one establishment loves pushing the timing edge until one day you get on it (usually in the fall/winter) and bang I nice hole in your piston.
    PS Matt's link is nice
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: Ideal timing
    Hagerstown,Md
    Well having 5 full years of tuning these cars Im pretty kean to what works and what doesnt. I was with the small pulley crowd 16 wot timing for the longest time but I can tell you that the track times people including myself are getting Blow. Im changing up the tune and rolling with high timming low Boost and seeing what happens. More timing almost always means more power. Unless your talking very High timing which will eventually have deminishing returns. Ill report back to my track times. 16 degrees in my car with a higher compression engine build BLOWS. Its a turd....SOrry im sick of running 14's in a intercooled headered set up lol
  6. #6 Re: Ideal timing
    Hagerstown,Md
    I will also Entertain the idea of running a 3.25 and 16 wot and seeing what happens
  7. #7 Re: Ideal timing
    m90 is a low boost blower anyway. its best at around 12 psi max.
  8. #8 Re: Ideal timing
    Hagerstown,Md
    NannyLog(01.10.2000_22.30.26). from GPGT01 -- Scan Depot dot net Droped to 19 WOT. Cars never pulled this hard at the top end. I gonna lean it some. This is still fueling for the 3.4 pulley so its alittle fat. I gonna test this setup and see what happens
  9. #9 Re: Ideal timing
    i always liked running stock timing and small pulleys. bigger boost numbers and more whine. i didnt really car if the car was faster on a bigger pulley with more timing.
  10. #10 Re: Ideal timing
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    im running 28 at wot lol but im waiting for winter to get injectors as im rebuilding the motor.....on another note..we should try and go above 12 psi boost? im at 10.5 now with a 3.2 pulley and about to remove the intercooler so i guess im about maxed
  11. #11 Re: Ideal timing
    you can't run 28* and if you do, then you're not benefiting from it.
  12. #12 Re: Ideal timing
    Feb 2010
    somewhere cold
    if i lower it my butt dino gets sad so im assuming its doing something..any yes i can run 28 as i am....i squack tire leaving first at 48 mph (i know its set wrong but i like it and dont mind buying trannies) and i can get a car length away from a new gt mustang before i hit 40 so im good with 28 till rebuild time...did i mention my tranny started slipping today lol oh trannyman i need u...lol
  13. #13 Re: Ideal timing
    Jan 1970
    Maquoketa, Iowa
    There is a lot of fail in this thread, but more timing always prevails over trying a smaller pulley. The m90 cars always like to be run leaner and more timing rather than boost.
  14. #14 Re: Ideal timing
    your advice is full of fail.
  15. #15 Re: Ideal timing
    Jan 1970
    Maquoketa, Iowa
    Your experience is lacking.
    Because I don't have an m90 car other than the couple I have tuned, here is a good one below:
    The car runs 26* of timing tops with a timing curve that goes up with the rpm's. It's the highest trapping, fastest non sponsored m90 only car. He also runs it leaner than **** on race gas.
    YouTube - Shawn Mayes Grand Prix GT
    I don't really have time to be on this forum anymore, so i'll discuss some other time.
    I've also put a regal into the 12.7x range with a 3.3 pulley non-ic with little tuning and he wanted me running it in the 10.8-11.2 afr range.
  16. #16 Re: Ideal timing
    Really, I mean...have you sat behind a tuner as much as he has? Sorry man, I doubt it.
  17. #17 Re: Ideal timing
    Hagerstown,Md
    I agree Fosh, And seeing shawns car and a few others is what had me going from lower pulleys to higher pulleys with higher timing. My times are CHit compared to what they should be. I can tell you that as ive went up in pulleys and made less of a spark curve and kept the timming pretty consistent its pulled much better. Im hoping to hit the track tomorrow or sunday and seeing positve results. Im not going balls to the wall as Im looking for relibility as well.
  18. #18 Re: Ideal timing
    fosh is right, matt. there are points of diminishing gains, but more timing is almost always better.
  19. #19 Re: Ideal timing
    I said his advice sucks because he didn't offer anything other than our advice sucks.
    If my advice sucks, I wanna know why, because learning is good.
    Oh i see what happened here.... The bastard edited it AFTER I POSTED!@#
    So now i look like an ass.
    Thanks guys for reading the times on these things...
    When I posted this is all that was there: There is a lot of fail in this thread
    Or something to that effect.
    Fosho... I shake my fist at you....
  20. #20 Re: Ideal timing
    Jan 1970
    Maquoketa, Iowa
    Like i said, i dont have much time with everything else goin on. I go to work, get home and go to work on the farm. I have just about enough time to see a few posts and then leave. Also, the laptop im on hates this forum, i type a message, then it just sits and acts like its loading. If i post right away, it lets me edit all I want, so you may see some of my posts with some bs in them, im usually editing them so i can actually post... lol
    To the OP, what mods do you have on your car? Can't really suggest anything without knowing what you have done to it so far. All i can tell is from your avatar it looks like your running an intercooler or a shiny rad? But if you say your running a 3.4-6ish pulley, i doubt you have an intercooler? I would just have a couple of different tunes and play with it at the track.
  1. N/A Cam timing
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2009, 01:12 AM
  2. Timing and other numbers...
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2009, 07:36 AM
  3. Need advice for an ideal system...
    By Vespers47 in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2009, 04:14 PM
  4. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
  5. Ideal exhaust cutout loc.?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-03-2008, 02:40 PM
