Thread: HID install pics?
Results 1 to 7 of 7
  1. #1 HID install pics?
    SE Level Member pghtattooer's Avatar
    pittsburgh,pa
    can anyone tell me and or even show me pictures of how and where to install/mount the h.i.d headlight conversion kit in a 2006 grand prix? i cant figure it out....i have a feeling this might be a simple answer but if someone could help me out that be awesome! thanks!
    ~dan
  2. #2 Re: HID install pics?
  3. #3 Re: HID install pics?
    West Side Michigan
    You can mount them wherever you want. You can use zip ties or two way tape, or whatever you want, just make sure it's secure.
    Without a relay harness:
    Disconnect stock bulbs form harness. There should be a plug going to the ballast that plugs into where the stock headlight bulbs used to plug in. After you plug that in, plug the HID Bulb into the ballast and voila...
    As simple as that.
    Stock headlight harness>ballast>HID Bulb
  4. #4 Re: HID install pics?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    When I installey ballasts I put them inside the fenders and tie rapped them down so they could move and they are semiprotected from rain and snow
  5. #5 Re: HID install pics?
    pittsburgh,pa
    OK thanks guys! 1more thing the instructions I have say to disconnect the drls I can't seem to figure that part out I was told they wont work with them still active
  6. #6 Re: HID install pics?
    West Side Michigan
    They will work with your DRL's active... but, they'll be receiving less power to the ballasts. This will eventually kill your ballasts.
    What year is your Grand Prix?
  7. #7 Re: HID install pics?
    pittsburgh,pa
    Its a 2006. I know it can be done I've seen people that have them installed on the same Gen as mine...
