Thread: Can L36 rockers/pushrods work on L67 heads?
Results 1 to 10 of 10
  1. #1 Can L36 rockers/pushrods work on L67 heads?
    Grand Island, Nebraska
    Ok so i need some L67 heads for my top swap, but if i find a set of heads thats been torn down, what exactly can i take off my L36 heads and put onto the L67 heads?
  2. #2 Re: Can L36 rockers/pushrods work on L67 heads?
    Lifters, rods, rockers, bolts, springs, retainers, and locks are all the same.
    You will want aftermarket bolts though. They are TTY.
  3. #3 Re: Can L36 rockers/pushrods work on L67 heads?
    and if you EVER plan on taking the heads off again.... get head studs.
    Get reusable rocker bolts for sure, they're a dollar more...
  4. #4 Re: Can L36 rockers/pushrods work on L67 heads?
    Alright thanks for the info guys, makes my head search a little easier. And ill definitely spring for the head studs and reusable rocker bolts.
  5. #5 Re: Can L36 rockers/pushrods work on L67 heads?
    FWIW...if you have a ACE hardware close to you...you can get the re-useable rocker bolts there for like 70 cents a pop LOL Same exact bolt as the comp ones...I've been running them since I had rockers 3 years ago. Just a little dab of loctite and bam. Re-usable rocker bolts for under $9.
  6. #6 Re: Can L36 rockers/pushrods work on L67 heads?
    shiiiz lol thanks. Oh and what about valve covers? can i use my old ones too?
  7. #7 Re: Can L36 rockers/pushrods work on L67 heads?
    Bump
  8. #8 Re: Can L36 rockers/pushrods work on L67 heads?
    you HAVE to lol
  9. #9 Re: Can L36 rockers/pushrods work on L67 heads?
    Lol ok well i didnt want to buy new ones if i didnt have to.
  10. #10 Re: Can L36 rockers/pushrods work on L67 heads?
    true.
    and by that i mean you have to use your own rocker covers.
  1. Can I run stock pushrods with H.S. 1.9 RR's?
    By jlturbos in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 03:42 PM
  2. Do L67 heads work with L36 bolt on?
    By bunker in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2010, 01:29 AM
  3. Rockers and Pushrods ? Pre-Mature ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-06-2010, 09:09 PM
