Thread: wondering about outer tie rod
Results 1 to 6 of 6
  1. #1 wondering about outer tie rod
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i was wondering if anyone knows of a thread for taking out and installing a new outer tie rod, or if you know how.. i couldnt find one on here, and i have not a clue on how to install one. thanks
  2. #2 Re: wondering about tie rod
    are we taliking inner tie rod or outer tie rod.
  3. #3 Re: wondering about outer tie rod
    outer tie rod.. i should of made that more clear
  4. #4 Re: wondering about outer tie rod
    Donating Users
    South Deerfield, MA
    Easy to replace. Break the jam nut on the tie rod loose. Take the nut off the bottom of the tie rod end. You might need to hit the bottom of the tie rod with a hammer to knock it out of the knuckle. Spin the tie rod end off of the tie rod. Reassemble and then get the front end aligned.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: wondering about outer tie rod
    how do i get it alligned.. i installed the tie rods, and tomorrow im doing the hub assembly. do i have to go to a place to get the allignment done. its probably alot of money
  6. #6 Re: wondering about outer tie rod
    Brewcity, WI
    iirc I got a 4 wheel alignment for $70, think just a front was $50
    yes you are going to need to take it to a shop
    Self-denied SMGPFC member #1
    SEARCH works!
  1. just wondering
    By mcsddd in forum General Tech Discussion
    Last Post: 08-10-2010, 12:19 PM
  2. just wondering....
    By iroc2 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2010, 11:07 PM
  3. Just wondering if.......
    By chancinit666 in forum Tires & Wheels
    Last Post: 06-06-2010, 12:29 AM
  4. just wondering
    By chuy09 in forum Audio, Security & Visual Electronics
    Last Post: 08-10-2009, 10:32 PM
  5. Just wondering
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 12-23-2007, 12:31 AM
