Thread: valve ticking or something else.
Results 1 to 18 of 18
  1. #1 valve ticking or something else.
    SE Level Member quadracer960's Avatar
    indiana
    Tonight i was driving without the radio and i got on it a little bit, 1/2 to 3/4 and i noticed there was a ticking sound that went with the rpm.I havent really noticed it to much before. When i rev in park, it doesnt really do it. Do you think im hearing valve tick or something else with the motor.
  2. #2 Re: valve ticking or something else.
    could be a VERY noisy injector. Its hard to say.
    Try running seafoam in the car to clear up the built up and clean the injectors. it might help.
  3. #3 Re: valve ticking or something else.
    indiana
    ill try this weekend.
  4. #4 Re: valve ticking or something else.
    Minnesota
    I have this same thing going on on thats what i think ita a lifter of something. I ran seafoam and its still making the noise. And this is whats stopping me from dropping pulleys
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  5. #5 Re: valve ticking or something else.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Probably a exhaust leak
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: valve ticking or something else.
    Or lifter tick. Something very common with these cars. Try Lucas Oil Stabilizer.
  7. #7 Re: valve ticking or something else.
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    same thing in my car. It started ticking in my car after i put on a new intake. when urs ticks is it inbetween 2-3 rpm?
  8. #8 Re: valve ticking or something else.
    indiana
    Eh the tick goes with rpm but only under a load and over 2500rpm. In neutral it wont tick, or barely at all. What would that oil stabilizer do? I just literally changed my oil 2 days ago, mobile 1 10w30.
  9. #9 Re: valve ticking or something else.
    Because if you put the oil stabilizer in and it quiets down then it is a valvetrain related noise.
  10. #10 Re: valve ticking or something else.
    My evap solenoid ticks nice and loudly....
  11. #11 Re: valve ticking or something else.
    Minnesota
    yea mine goes away on heavier throttle, i used seafoam and still have it, could it be an injector? I heard those will tick
  12. #12 Re: valve ticking or something else.
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    another problem these engines have is connection rods breaking. but the noise is more of a clak clak clak and you dont notice it under 2000 rpms then gets loud. had this problem in my old bonneville and and connection rod eventually came out the side of the block!
  13. #13 Re: valve ticking or something else.
    indiana
    I hope its not that^^^^
  14. #14 Re: valve ticking or something else.
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    try and get a vid of the ticking
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  15. #15 Re: valve ticking or something else.
    indiana
    itll be hard to hear because of my loud ass slp exhaust. but if it goes with rpm, it might be it? I mean anything ticking coming from the motor isn't good right? And im buying oil stabilizer tomorrow even though its 5 days fresh.
  16. #16 Re: valve ticking or something else.
    Quote Originally Posted by RyanL View Post
    Then you needed the right foot delete mod.
  17. #17 Re: valve ticking or something else.
    whats that? lol
  18. #18 Re: valve ticking or something else.
    SE Level Member SlprGS's Avatar
    Greensboro, NC
    i assume it means keep your foot off the pedal..lighten the load... i have similar ticking.. i believe it's an exhaust leak from the egr, so I'm going to delete it.. if that doesn't work, then I guess I'll start saving for a new motor or a rebuild
  1. Ticking at start up
    By Nick24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2009, 08:12 PM
  2. another ticking question
    By stainlessguy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-25-2009, 07:45 PM
  3. DP ticking
    Last Post: 03-01-2009, 11:39 PM
  4. Ticking
    By theboss98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:17 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
