Thread: Car running hot
Results 1 to 20 of 21
  1. #1 Car running hot
    SE Level Member ShinyWhite99GTP's Avatar
    Midwest
    I have a 99 gtp. I have a k&n cold air intake, 3" bolt in down pipe with cat bolted to a stock exhaust, 180 t-stat, 3.5 pulley, autolite 104 spark pulgs. i just had the thermostat, pulley, and plugs put in yesterday. The car was running 2 notches below the large notch that is in the middle of 160 and 210 on the oil temp guage. As it later tonight it was running 3 notches away from 210, it never gets that hot. I read in the reviews on the zzperformance website that the gaskets that are sent with the thermostats are garbage. Anybody have any suggestions as to what the problem may be?
  2. #2 Re: Car running hot
    do you have a tune?
  3. #3 Re: Car running hot
    Willoughby, Ohio
    and if you do is it tuned for that thermo?
  4. #4 Re: Car running hot
    Midwest
    no, no tune
  5. #5 Re: Car running hot
    Willoughby, Ohio
    ok...you need a tune
    now
    with ANY pulley drop you NEED a tune, even the thermo needs tune
  6. #6 Re: Car running hot
    Midwest
    ok how to i do that, can you send the a link to the product i need to buy?
  7. #7 Re: Car running hot
    Willoughby, Ohio
    1. a custom tune will be the best for you if you can find a local tuner or buy the software and learn yourself
    2. you can send you PCM to some people on our forums like reptile and he will tune it to your needs
    3. you can buy a tuned PCM from either
    PCM for Grand Prix GTP v1.0: 3800 Performance
    or
    INTENSE-Racing.com: INTENSE
  8. #8 Re: Car running hot
    Midwest
    Ok thanks. It's working fine today though. It probably just got mad at me cuz I was watching corvette videos on streetfire.net.
  9. #9 Re: Car running hot
    Willoughby, Ohio
    ...or because you have a pulley an no tune
  10. #10 Re: Car running hot
    Midwest
    yea thanks man, i think im gonna get the standard pcm from intense
  11. #11 Re: Car running hot
    Willoughby, Ohio
    sounds good, i wanna keep your car running properly thats all
    so you can enjoy it!!
  12. #12 Re: Car running hot
    since when does changing a thermostat require a tune ??
  13. #13 Re: Car running hot
    if you change the temp.... fan settings need to be moved
  14. #14 Re: Car running hot
    that i can understand or you can get resistors to adjust the fan temp too
  15. #15 Re: Car running hot
    i wouldnt do that....
  16. #16 Re: Car running hot
    Midwest
    i installed the standard intense pcm, its amazing, i think im done with the engine now, im gonna get some 18' rims and lower it an inch or 2
  17. #17 Re: Car running hot
    Willoughby, Ohio
    good to hear, post pics after the drop and rims!
  18. #18 Re: Car running hot
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    i ran the fan off constant power and put in my own temp control. set it where i want!
    autozone ftw!
    <MiZzBeCcA>its not rape if you yell suprise
  19. #19 Re: Car running hot
    Willoughby, Ohio
    ^^^sice its relevent, please explain
  20. #20 Re: Car running hot
    Nov 2008
    Chicago
    He has a thermostat that kicks the fan on at the preset temp that he chooses. It's like the thermostat in your house.
    PS- Dont buy a ZZP PCM. Before you ask why, do a search.
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  1. Who's running low 14's?
    By Louie3 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:24 AM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. running hot ??
    By rickchall69 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2009, 02:55 PM
  4. Is 210 running hot?
    By NewImage in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2009, 11:11 PM
  5. Running Hot
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 10:41 AM
