Thread: CV axle: snap ring and abs ring
Results 1 to 6 of 6
  1. #1 CV axle: snap ring and abs ring
    Jul 2010
    Outside ATL
    i got a new pass axle and it didnt come with a new snap ring for trans, can i reuse my old one or should i run to the parts store. Also, i dont see an abs ring on the axle, whats up with that. HELP should i send it back, what can i do.
  2. #2 Re: CV axle: snap ring and abs ring
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    not sure what an "abs ring" is, but the snap ring stays inside of the transmission..... there is not supposed to be one on the shaft
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: CV axle: snap ring and abs ring
    Charles City, IA
    These cv shafts do not have abs rings on them. It is all in the wheel hub.
    SMGPFC Two Nipple General
  4. #4 Re: CV axle: snap ring and abs ring
    Jul 2010
    Outside ATL
    good to know, thanks.
  5. #5 Re: CV axle: snap ring and abs ring
    are you guys telling him?
    The part of the axle that goes into the trans aka diff housing should have a compression ring on it that does keep the axle in the diff. It's not quite a snap ring, but it does compress etc, you should see the groove and it should have come on the axle.
    As for the ABS ring, the ABS sensors on our cars are build into the wheel bearing. Therefore there is nothing on the axle.
  6. #6 Re: CV axle: snap ring and abs ring
    Nov 2008
    Fremont Nebraska
    well whatever kind of ring it is, it stays in the transmission when the shaft is pulled out. when i pulled my shaft out there was no ring on it, and no ring on the new shaft.
  1. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  2. o-ring for temperature sensor?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 04:06 PM
  3. PCV Valve O-Ring?
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:25 AM
  4. Where do I get this? Ring Gapper
    By TubbedGTP in forum General Tech Discussion
    Last Post: 08-22-2008, 04:05 AM
