Thread: ZZP?
Results 1 to 20 of 24
  1. #1 Re: ZZP?
  2. #2 Re: ZZP?
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    well if your build is under 500 crank hp then youd be fine with any good condition used motor. anything over that mark would prolly require some stronger parts. an l32 is prolly the best start as they come with some stronger parts. lets put it this way. if youre gonna stay with the m90 then just go with a used block if you go turbo i suggest a built block.
    2000 Daytona GTP(aka the slow fwd GTO)
zzp
