Thread: Can I safely run a 3.5 pulley?
Results 1 to 6 of 6
Threaded View
  1. #1 Can I safely run a 3.5 pulley?
    SE Level Member ShinyWhite99GTP's Avatar
    Midwest
    I have a 99 GTP with almost 138,000 miles. I have a K&N CAI, a 3'' bolt-in downpipe with cat from zzperformance, I have a 180 t-stat, and I also just had my s/c coupler replaced and s/c oil changed. I already have a 3.5 pulley on the way. Is that enough to safely run the 3.5? I don't want to put too much stress on my engine considering that it has 138,000 on it already. Ive noticed that it has been leaking a little bit of oil since I had the downpipe installed and the coupler replaced. It used to leak about a year ago, it stopped when the drainplug was replaced. The car is running better than ever, I'm hoping the leak isn't related to me adding more power to the engine and its just the drain plug again. I'm an auto-detailer not a mechanic so help would be appreciated. Please let me know what you think. Thanks.
  1. Safely dropping my pulley size.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-30-2010, 09:08 AM
  2. does anyone know how to remove the rails on the door safely?
    By rambo33 in forum Visual/Body Modifications
    Last Post: 09-13-2009, 12:51 AM
  3. Can this be safely fixed?????
    By YoungGTP in forum Visual/Body Modifications
    Last Post: 11-10-2008, 11:24 AM
  4. Smallest pulley size to run safely...
    By chipsdubbo89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 07:15 PM
  5. What would i have to do to safely run a 3.0 inch pulley?
    By John_Shughart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2008, 02:56 PM
