^^Agreed. You need to ask them for the intake PLENUM gasket. Should be part #MS96789 at ORiellys. Then again...the GenV is a metal gasket and your also paying for the TB gasket, PCV Valve gasket...etc. It does sound a bit pricey but you have to figure since you've got a GenV car...its is a tad more expensive. The GenIII gasket however is $9.99...and you might be able to cut it to match the GenV one if you want to go about it that route...but I'm not guaranteeing that to work. It is part #MS95744
