Thread: Problem solved p0101
Results 1 to 2 of 2
  1. #1 Problem solved p0101
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Ok so it wasn't my MAF or my MAP sensor. It turned out that my supercharger actuator got busted (happened after I got the recall). I don't ever recommend letting anyone work on your car if you can just DIY. My lines were even broken so therefore it was a vaccum issue. So just telling u in case you are troubleshooting just tryin to be helpful.
    Special thanks to fivefingerdeathpunch, bio, matt5112, torquemotive, ctkgp, reptile, bluegtp, and all the others that tried helping.
  2. #2 Re: Problem solved p0101
    Willoughby, Ohio
    glad you got it fixed man
  1. Does my car have Remote Start? -- Solved
    By SyriusX in forum General Tech Discussion
    Last Post: 12-01-2010, 06:30 PM
  2. Rear Suspension Chirp (Solved)
    By Crymson in forum Brakes/Suspension/Chassis
    Last Post: 07-17-2010, 01:48 PM
  3. P0101 and p0172 Codes??
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2010, 11:55 AM
  4. SES Code P0101 ( MAF Sensor Low voltage)
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2010, 03:01 PM
  5. P0101 Code
    By JB381 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2010, 12:20 AM
