Thread: Ac compressor making noise
Results 1 to 14 of 14
  1. #1 Ac compressor making noise
    Apr 2009
    stockton ca
    Let me rephrase it makes a horrid screeching as if something were diing a horrid painful death
    Is there anything that might beable to make this subside till i can fix this properly
    I was thinking about just doing an ac delete pulley till then but I dont know
  2. #2 Re: Ac compressor making noise
    Charles City, IA
    Leave the ac off. Its winter.
    SMGPFC Two Nipple General
  3. #3 Re: Ac compressor making noise
    DevilsOwn
    Guest
    Its more than likely the clutch going out on it
  4. #4 Re: Ac compressor making noise
    Apr 2009
    stockton ca
    It makes noise no matter if its on or off i may pick up a ac delete pulley cause its a cheap fix
    I think the ac comp isnt sitting properly right now looks a little off Im going to pull it off and check it out
  5. #5 Re: Ac compressor making noise
    DevilsOwn
    Guest
    the a/c should cycle on and off with the heat on when its not on full blast, this helps add moister to the incoming air.
  6. #6 Re: Ac compressor making noise
    Apr 2009
    stockton ca
    It just makes noise regaurdless no air on no heat on gets worse with the heat on but not by much
    What do i need to replace the clutches any specialty tools?
    Im going to have to do something its annoying as all hell
  7. #7 Re: Ac compressor making noise
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Welcome STEFAN MUELLER
    Leading source of Online Diagnostic & Repair Information
    ACCOUNT
    VEHICLE
    HELP
    SEARCH
    CONTACT
    EXIT
    Your Vehicle: 2000 Pontiac Grand Prix V6-3.8L SC VIN 1
    Vehicle » Heating and Air Conditioning » Compressor HVAC » Compressor Clutch Bearing » Service and Repair » Clutch Rotor and/or Bearing Removal » V5 - Conventional Mount Notes
    TOOLS REQUIRED
    J 6083 Snap Ring Pliers #24 External
    J 9398 Rotor Bearing Remover
    J 8092 Driver Handle
    J 33020 Pulley Puller
    J 33023-A Puller Pilot
    Remove the clutch plate and hub assembly.
    Use the J 6083 in order to remove the rotor and bearing assembly retaining ring.
    Install the J 33023-A to the front head.
    Install the J 33020 into the inner circle of slots in the rotor.
    Turn the J 33020 clockwise in the slots in order to engage the tangs of the puller with the segments between the slots in the rotor.
    Hold the J 33020 in place. Tighten the puller screw against the puller guide in order to remove the puller rotor and bearing assembly.
    Support the rotor hub in order to prevent damage to the pulley rotor during bearing removal.
    7.1. Remove the forcing screw from the J 33020.
    7.2. With the tangs of the J 33020 still engaged in the rotor slots, invert the assembly onto a solid, flat surface or blocks.
    NOTE: It is not necessary to remove the staking in front of the bearing to remove the bearing, however, it will be necessary to file away the old stake metal for proper clearance for the new bearing to be installed into the rotor bore or the bearing may be damaged.
    Use a J 9398 with the J 8092 in order to drive the bearing out of the rotor hub.
    Account | Vehicle | Help | Contact | Exit
    © 2010 ALLDATA, LLC. All Rights Reserved. Trademarks | Privacy Policy | Terms and Conditions
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  8. #8 Re: Ac compressor making noise
    Oklahoma City
    Hell remove the AC.. you got the CV to drive around
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  9. #9 Re: Ac compressor making noise
    Apr 2009
    stockton ca
    Quote Originally Posted by Ibwrong View Post
    I wish it was that easy the wifes dd is on its death bed and i dont wanna fix it she should have a new car by feb though
    Thanks for the info Ill look into it
  10. #10 Re: Ac compressor making noise
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Sounds like a bad A/C clutch to me. Follow the directions above to solve your problem
    For all your 3800 needs:
  11. #11 Re: Ac compressor making noise
    Apr 2009
    stockton ca
    Ok so i got my a/c delete pulley today
    Any one on here with one it came ith some bushings and washers to use as spacers just curious if any one had alignment issues
  12. #12 Re: Ac compressor making noise
    SE Level Member lisas1998gtp's Avatar
    texas
    did mine today in about an hour and a half...no biggie and cost $58 . better than 260 when it still worked great just noisy. now nice and quite qnd still works great.
  13. #13 Re: Ac compressor making noise
    SE Level Member 2kgtp's Avatar
    minnesota
    Quote Originally Posted by lisas1998gtp View Post
    Did your pulley for $58? or replaced the whole unit...? Mines going bad now and I'm unsure what to do at the moment... I dont want a belt snapping on me leaving me stranded...
  14. #14 Re: Ac compressor making noise
    toledo, ohio
    My compressor pulley is grinding and spitting shavings also. There is an aluminum tube coming from a hose fitting near the firewall under the master cylinder that has been cut and pinched off. It seems like a royal mess and I dont have the money or time to deal with it. I DONT want to throw my belt if the pulley seizes on me so should I..........
    A. Replace the bearings in the compressor
    B. Remove the compressor and install a bypass pulley.
    Looking into the engine bay I stumped as to how the compressor can even be removed. If I replace the bearings, how long until it has to be replaced again?
  1. Stering Making Noise - Shaft Problem
    By anishtulsian in forum General Tech Discussion
    Last Post: 12-23-2009, 04:20 PM
  2. 98 GTP making noise by supercharger?
    By hunter_alexander in forum General Tech Discussion
    Last Post: 07-30-2009, 07:32 PM
  3. UPDATE on trans flush making noise!
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2009, 01:53 AM
  4. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  5. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
