Thread: Ac compressor making noise
Results 1 to 14 of 14
  1. #1 Re: Ac compressor making noise
    SE Level Member lisas1998gtp's Avatar
    texas
    did mine today in about an hour and a half...no biggie and cost $58 . better than 260 when it still worked great just noisy. now nice and quite qnd still works great.
  2. #2 Re: Ac compressor making noise
    SE Level Member 2kgtp's Avatar
    minnesota
    Quote Originally Posted by lisas1998gtp View Post
    Did your pulley for $58? or replaced the whole unit...? Mines going bad now and I'm unsure what to do at the moment... I dont want a belt snapping on me leaving me stranded...
  3. #3 Re: Ac compressor making noise
    toledo, ohio
    My compressor pulley is grinding and spitting shavings also. There is an aluminum tube coming from a hose fitting near the firewall under the master cylinder that has been cut and pinched off. It seems like a royal mess and I dont have the money or time to deal with it. I DONT want to throw my belt if the pulley seizes on me so should I..........
    A. Replace the bearings in the compressor
    B. Remove the compressor and install a bypass pulley.
    Looking into the engine bay I stumped as to how the compressor can even be removed. If I replace the bearings, how long until it has to be replaced again?
  1. Stering Making Noise - Shaft Problem
    By anishtulsian in forum General Tech Discussion
    Last Post: 12-23-2009, 04:20 PM
  2. 98 GTP making noise by supercharger?
    By hunter_alexander in forum General Tech Discussion
    Last Post: 07-30-2009, 07:32 PM
  3. UPDATE on trans flush making noise!
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2009, 01:53 AM
  4. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  5. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
