Thread: Im new to this forum and i cant figure out whats wrong with my car
Results 1 to 20 of 20
  1. #1 Im new to this forum and i cant figure out whats wrong with my car
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i have a 2000 pontiac grand prix and when im driving and turn the wheel i hear like a clicking sound and can feel it when i keep my hand on the shifter. so i started to turn my wheels left and right constantly and i feel and hear the clicking so much.. when i jack my car up my front wheels are kinda loose when you shake them forward and back. and when i make right turns my wheel makes alot of squeaking. i dont know if it could be one of the control arms or something along that line.. if anyone has any ideas i would love to get some help, thanks.
  2. #2 Re: Im new to this forum and i cant figure out whats wrong with my car
  3. #3 Re: Im new to this forum and i cant figure out whats wrong with my car
    ive never heard of that.. whats a hub
  4. #4 Re: Im new to this forum and i cant figure out whats wrong with my car
    Jul 2010
    Manitoba
    hub assembly, these cars use a sealed roller bearing and the only way to change it is to buy a complete hub assembly.
    now do you only have play when you "shake" the wheels side to side or does it do it up and down as well? does it only make the noise when turning? is it just when you start to turn or is the noise throughout the turn? is it make it turning both ways? is there a loud humm or drone at higher speed?
  5. #5 Re: Im new to this forum and i cant figure out whats wrong with my car
    when the car is jacked the wheels are only loose left and right.. and the wheels only squeak when i make right turns and its throughout the whole turn, and sometimes it doesnt squeak when im pushing down on the break through the turn
  6. #6 Re: Im new to this forum and i cant figure out whats wrong with my car
    Willoughby, Ohio
    i agree on the new wheel bearing/hub assembly idea, got any vibration in your steering wheel at highway speeds?
  7. #7 Re: Im new to this forum and i cant figure out whats wrong with my car
    Jul 2010
    Manitoba
    does it make noise at speed? when turning right what side is the noise coming from?
  8. #8 Re: Im new to this forum and i cant figure out whats wrong with my car
    yaeh i get vibrations sometimes when im driving on the highway.. and the squeaking sound seems like its coming from the front right wheel
  9. #9 Re: Im new to this forum and i cant figure out whats wrong with my car
    Canada
    wheel bearing sounds like.. if it makes a vibration and a loud noise on highway prob ur wheel bearing, or if its a noise when ya turn could be a tie rod end...
  10. #10 Re: Im new to this forum and i cant figure out whats wrong with my car
    i feel like it could be so many different things.. i think im just going to buy the hubs and put them in and hopefully that fixes the problem.
  11. #11 Re: Im new to this forum and i cant figure out whats wrong with my car
    Willoughby, Ohio
    even if it doesnt fix the problem its something that will go bad in the future so you wont have to worry about it then
  12. #12 Re: Im new to this forum and i cant figure out whats wrong with my car
    yeah very good point.. hey how do you get that picture next to your name.. on mine it says No Avitar. whatever that means
  13. #13 Re: Im new to this forum and i cant figure out whats wrong with my car
    Willoughby, Ohio
    edit your profile and click edit avatar in the left hand column
  14. #14 Re: Im new to this forum and i cant figure out whats wrong with my car
    thanks man
  15. #15 Re: Im new to this forum and i cant figure out whats wrong with my car
    Charles City, IA
    Have some one shake the tire and look behind it and see whats moving, then replace that part simple.
    SMGPFC Two Nipple General
  16. #16 Re: Im new to this forum and i cant figure out whats wrong with my car
    when i got my new tires i asked the guy if he knew what was loose and he didnt really know, he said its a hub or your lower control arm
  17. #17 Re: Im new to this forum and i cant figure out whats wrong with my car
    Willoughby, Ohio
    a hub OR control arm? ok he didnt really look at it that much
  18. #18 Re: Im new to this forum and i cant figure out whats wrong with my car
    yeah he didnt really look to hard.. maybe if i gave him some money he would of tried to look a little harder lol
  19. #19 Re: Im new to this forum and i cant figure out whats wrong with my car
    Wichita
    Check the tie rods
  20. #20 Re: Im new to this forum and i cant figure out whats wrong with my car
    PCMO
    I had same problem. when jacked if the wheel moves side to side it is tie rods and control arms. up and down is Hub. I replaced all. Make sure if you have ABS you get the hub with ABS pigtail wire. I recommend replacing rods and control arms and hubs and get realignment done. I have also replaced Strut assemblies(struts and springs took 2hrs) 2000 GTP 150,000 miles.
  1. whats wrong with my car now?!
    By mezzoni in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2010, 12:41 AM
  2. I dont know whats wrong
    By beezeebaby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2009, 01:15 PM
  3. Whats wrong with my car?
    By basshead42 in forum General Tech Discussion
    Last Post: 07-01-2009, 04:25 PM
  4. Trying to figure out whats wrong with my car
    Last Post: 05-08-2009, 01:13 PM
  5. whats wrong with the se?
    By blazedgp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2008, 09:20 AM
