Thread: what are the proper oil pressure readings
Results 1 to 2 of 2
  1. #1 what are the proper oil pressure readings
    what is the proper oil pressure readings for a 3800 s/c engine (stock) at idle and and at higher rpms, im reading at a cold start 40 to 45 psi idling and revving it up some im getting over 50 psi. damn kit only gave me 5 feet of tubing to work with so all i could do was a hook it up and see what im getting, ill need a longer tubing kit to get to the A-pillar, unless there is someplace else i can tap into to get oil pressure readings closer to the driver side of the engine bay, any thoughts? thanks Scott
  2. #2 Re: what are the proper oil pressure readings
    Charles City, IA
    That sounds find for pressure, should have got an electric gauge.
    SMGPFC Two Nipple General
  1. O2 readings
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 10:44 PM
  2. Proper way to seafoam 04+ S/C?
    By dirtmaster88 in forum 04+ Specifics
    Last Post: 01-11-2010, 04:32 PM
  3. Proper Alternator to purchase for 04 GT2
    By proofinlife in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 11:48 PM
  4. Proper gap for plugs
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 08:15 PM
  5. O2 readings
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2008, 02:24 PM
