Went from a l36 TB to a l67 TB. I reused all the l36tb's sensors. The car runs great. on my tune the only changes I made was to drop 2 degrees of timing so id be safe doing a WOT pull and getting a baseline on fueling. Injector Duty Cycle was 98percent(GTP injectors) and maf hit 10,680Hz before the tb After the TB maf only hits 10,100 and IDC hits 79 percent. did I do wrong. TPS reads 100percent. Its to dark out to check to see if the blade is 100 percent open. I had no knock
