Thread: Work performed over the last two days
Results 1 to 13 of 13
FuglyGTP Work performed over the last... 08-24-2010, 09:20 PM
03GTPLE Re: Work performed over the... 08-24-2010, 09:28 PM
TheOtherNick Re: Work performed over the... 08-24-2010, 09:38 PM
03GTPLE Re: Work performed over the... 08-24-2010, 09:40 PM
FuglyGTP Re: Work performed over the... 08-24-2010, 10:35 PM
03GTPLE Re: Work performed over the... 08-24-2010, 10:42 PM
FuglyGTP Re: Work performed over the... 08-24-2010, 11:27 PM
TheOtherNick Re: Work performed over the... 08-25-2010, 05:47 PM
FuglyGTP Re: Work performed over the... 08-25-2010, 08:13 PM
TheOtherNick Re: Work performed over the... 08-25-2010, 08:23 PM
FuglyGTP Re: Work performed over the... 08-27-2010, 10:43 PM
03GTPLE Re: Work performed over the... 08-27-2010, 11:13 PM
FuglyGTP Re: Work performed over the... 08-30-2010, 10:41 AM
  1. #1 Work performed over the last two days
    Nov 2008
    Chicago
    -Removed front strut
    -Accidentally destroyed CV axle
    -replaced CV axle
    -Removed hub and replaced lug nut studs with longer ones
    -installed agx strut and eibach spring
    -bled brakes
    Now on to the passengers side
  2. #2 Re: Work performed over the last two days
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    nice one. did you replace the seal for the axle while you were in there?
    ....let us know if it starts leaking soon if you didn't.
    Sounds like fun. I'm doing my CV axle sometime this week. I did the hub last month...... get to rip it all apart again... at least it's easy the second time around
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  3. #3 Re: Work performed over the last two days
    Charles City, IA
    how did you destroy the axle?
    SMGPFC Two Nipple General
  4. #4 Re: Work performed over the last two days
    Tyler, TX
    probably stuck to hub when he pulled the hub off and it brought the outside portion with it.... that's my guess
  5. #5 Re: Work performed over the last two days
    Nov 2008
    Chicago
    Wasn't thinking and undid the nut on the top of the strut. Uncompressed spring shot the strut into the outer boot. Then the inner joint came undone spilling green splooge everywhere. One of the bushings fell on the floor and when I pushed it back on all of the "roller pins" that it goes over fell all over the place. At that point I just said fck it. It has 90k on it already and these things only cost $50.
    I removed the hub to replace the lug nut studs. My rims where being held on by like two threads. I've snapped the stock studs many many times.
  6. #6 Re: Work performed over the last two days
    Tyler, TX
    wow, much more dramatic than I thought! Have fun doing the other side.
  7. #7 Re: Work performed over the last two days
    Nov 2008
    Chicago
    The other side should be easy. This side wasn't hard it was just time consuming and I decided to do a bunch of things at once.
  8. #8 Re: Work performed over the last two days
    Charles City, IA
    Wow, good to see you did not take a spring threw the foot.
  9. #9 Re: Work performed over the last two days
    Nov 2008
    Chicago
    Actually, it wasn't too bad. If it where to hit me in a limb or chest I'm guessing I'd have a bump and a bruise at worse.
  10. #10 Re: Work performed over the last two days
    Charles City, IA
    Must have been pretty worn out then.
  11. #11 Re: Work performed over the last two days
    Nov 2008
    Chicago
    add disassembly of nearly all suspension components on the front passengers side. I was stranded in a parking lot for six hours tearing everything apart to replace lug nut studs. 4.5 hours of disassembly due to a very stuck and almost stripped hub nut and a hub that didnt want to come out.
  12. #12 Re: Work performed over the last two days
    Tyler, TX
    ouch man. I'm assuming it's all back together now....??
  13. #13 Re: Work performed over the last two days
    Nov 2008
    Chicago
    Yep. I put the last strut/spring on and threw some grease on the wheel bearing. It only took 45 min to tear it apart the second time.
    Now all i need to do is replace a dying battery, replace the drive belt tensioner pulley, get new front tires, flip the dogbones and seal the rear spoiler.
  1. Hello Just got my GP two days ago, and already
    By mojodare in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 11:29 AM
  2. 2 days after paint and...
    By AdamBall in forum The Rant Forum
    Last Post: 04-23-2010, 11:34 AM
  3. nostalgia days
    By nemesis in forum Shows and Events
    Last Post: 01-24-2010, 12:16 PM
  4. Where has GPF been for two days?
    By 03GPScottyd in forum Forum Bugs/Suggestions
    Last Post: 08-10-2008, 02:54 PM
