Thread: A/C issue
Results 1 to 4 of 4
  1. #1 A/C issue
    Donating Users
    South Deerfield, MA
    We lost the A/C in both of our cars this week. Her car is a 2003 Grand Am and it was low on freon. I noticed the clutch would engage for a couple seconds when the car was started, so I took a chance and charged it and now it works well. I think my GP is a bigger problem though. The A/C was on and we stopped at Autozone to pick up some oil and coolant for a car I was fixing. I left the A/C on the max setting and when we got back in the car 10 minutes later, the A/C didn't work anymore. The clutch does not engage for a couple seconds when started like her car did. There is good pressure in the system. My guess is that the clutch has gone bad or there is some type of relay that went out. I checked all the fuses related to the A/C and they are all good. I don't know much about A/C systems and could use some help on this one. Anybody have any suggestions on how to troubleshoot this one? Thanks.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: A/C issue
    swift current,sask.
    The only other thing that could cause the compressor to not engage would be the low pressure switch...
  3. #3 Re: A/C issue
    Jul 2010
    Manitoba
    could also be the high pressure cut-out, make sure your fans work, if not your high side will spike and cut the clutch out
  4. #4 Re: A/C issue
    Donating Users
    South Deerfield, MA
    I took the plug off the clutch and checked it. I was getting about 14 volts with the A/C running. I spun the clutch by hand to make sure it wasn't frozen up and now it works again. ??? I guess there is a dead spot in the mechanism that engages the clutch.
  1. NEED SOME HELP...possible map issue?
    By 01gpgt01 in forum General Tech Discussion
    Last Post: 07-20-2010, 06:10 PM
  2. Need Help Car issue
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 09:00 AM
  3. MAF Issue
    By prostallion347 in forum General Tech Discussion
    Last Post: 03-30-2010, 11:36 AM
  4. Another DiC issue
    By Wolf79 in forum General Tech Discussion
    Last Post: 02-17-2010, 02:53 PM
  5. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
