Thread: temp gauge pegged
Results 1 to 13 of 13
  1. #1 temp gauge pegged
    Dallas, GA 30157
    Car can sit for 18 hours, gauge sitting at rest (100) within 5 min
    it's in the red. You can touch the rad hoses and they
    are still cold to the touch, but I changed out the temp sensor (3x),
    rad (around a year ago) dropped t-stat to a lower temp and the problem
    has gotten progressivly worst. I use a infrared temp gun on it the other
    day and the highest it got was 180 (on hoses, t-stat housing, sending
    unit and radiator). Water pump is working, suspecting the gauge,
    but maybe the pcm. How hard is it to change out the gauge and is there
    anyway to check it. Is the pcm the same thing as an ecu?
    Thanks, Larry
    Mods: if posted in the wrong place lmk and please move it.
    just got back from having temp read on computer, showing 191 while the
    interior gauge is reading 80 more.
  2. #2 Re: temp gauge pegged
    HUDSON
    Have you check the engine coolant sensor, it is located in the intake manifold under the thermostat. You can chack the resistance with an ohm meter, and then compare that with the specs of the part (sorry I don't know what the readings should be), but this will tell you is you have a faulty sensor or not.
  3. #3 Re: temp gauge pegged
    Dallas, GA 30157
    That's the one I was calling the temp sensor.
    Have changed it out 3x's after reading about others getting a bad one.
    First 2 came from AZ and the last from Oreillys.
    Tried using ohm meter while still on the car and it went from nothing to
    almost infinite as the engine heated. I may change it out once again
    with one form a dealer. Crazy thing is, the computer is getting the correct
    readings.
    The shop I took it to today suggested another gauge. Opinion?
  4. #4 Re: temp gauge pegged
    Dallas, GA 30157
    Anyone know if there's a place to hook up an
    aftermarket temp gauge? (3.8)
    Thanks, Larry
  5. #5 Re: temp gauge pegged
    did you at least get the dealer temp sender?
  6. #6 Re: temp gauge pegged
    Dallas, GA 30157
    Not yet. My wife just took it to a local dealer today,
    They too are thinking gauge.
    Now to figure out to R&R it.
  7. #7 Re: temp gauge pegged
    Dallas, GA 30157
    Just thpught I'd update. Changed out gauge, but still had the same
    problem, so we (my son and I) replaced the original. Went to dealer
    this morning and got another sensor, seems to be working now.
    Now I've gotten another problem, got to change out the plenum
    gasket, it's leaking right behind the alternator.
    Anyone know if this is a hard job? Dealer wants $382.
  8. #8 Re: temp gauge pegged
    Charles City, IA
    not hard at all. ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information buy a subscription to your car and it will tell you basicly how to do everything.
    SMGPFC Two Nipple General
  9. #9 Re: temp gauge pegged
    Charles City, IA
    also get a new plenum. Factory ones melt around the egr tube.
  10. #10 Re: temp gauge pegged
    Dallas, GA 30157
    ^^ thanks, the dealer kinda' implied the same thing.
    It was also suggested to check out where the heater hose
    connects to the manifold, to the right and below the alternator,
    that it may be the cause of the leak and from what I can see, the
    leak looks very close to that point. Any input on that?
  11. #11 Re: temp gauge pegged
    The coolant elbows crack and leak. its most common.
    3100's have issues with the heater hose connectors.
  12. #12 Re: temp gauge pegged
    Dallas, GA 30157
    Is this also a problem on the 3800's?
  13. #13 Re: temp gauge pegged
    never heard of it, they're metal, the 3100 ones are plastic IIRC.
  1. Temp gauge not working
    By gabsgrammy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 06:04 PM
  2. Temp Gauge running hot
    By Thexfactord22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2010, 02:43 AM
  3. 94 GP with fluctuating temp gauge
    By Beyond Hope in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-22-2010, 09:19 AM
  4. Temp gauge
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 01:39 AM
