Thread: Check Tire Pressure light on with no low pressure.
Results 1 to 20 of 24
  1. #1 Check Tire Pressure light on with no low pressure.
    Feb 2008
    I was driving back from a visit to the parent's house yesterday, and about 10 miles to go, I get my "check tire pres." light. I pull over, check them, 35-36 all the way around. No hissing sound or anything like that. I get back in the car, start it, and the light is off again. Any idea what else may cause the light to come one like this?
  2. #2 Re: Check Tire Pressure light on with no low pressure.
    PA
    Quote Originally Posted by DanGTP View Post
    My car does this from time to time. Not sure what year your car is, but on my 97 the system doesn't really read the air pressure. It reads the differences in wheel speed. So I notice that the light will go off if I am driving slow and hit a bump/pothole. Or it could be a wheel speed sensor starting to go bad. And sometimes it goes off for no noticable reason.
    But when it does, I just reach under the dash and hit the reset button. If I really have a tire going flat, I just figure the light will come back on shortly.
    2001 GSE
  3. #3 Re: Check Tire Pressure light on with no low pressure.
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I believe mines on a timer like oil %. So about every few months it comes on. I reset and go omw.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  4. #4 Re: Check Tire Pressure light on with no low pressure.
    Feb 2008
    Well, good to hear that I'm not the only one having that problem. It hasn't come back on since, so I suppose it was just a random occurrence. And, yes, mine is a 97, too.
  5. #5 Re: Check Tire Pressure light on with no low pressure.
    PA
    I think you don't hear about this problem as often because it happens more to the 97 guys. The 97 GTPs had a different ABS system than the 98-03s got. And this must be an issue that was corrected with the newer system. But the ABS system in the 97s is the same reason that the 97 GTPs don't have traction control. It was a weak system all around.
    2001 GSE
  6. #6 Re: Check Tire Pressure light on with no low pressure.
    Feb 2008
    I've been just running around with the fuse pulled. I'll put it back in eventually...
  7. #7 Re: Check Tire Pressure light on with no low pressure.
    Feb 2008
    It's been a few weeks now, and I still have it come on and turn itself off when I shut the car down. Bumps in the road do seem to set it off quite frequently.
    Quote Originally Posted by Zef_66 View Post
    I've tried that, but it won't reset the system. Would having the ABS fuse pulled not allow it to reset the tire pressure light?
  8. #8 Re: Check Tire Pressure light on with no low pressure.
    PA
    That might have something to do with it. Why do you have the fuse pulled again?
    2001 GSE
  9. #9 Re: Check Tire Pressure light on with no low pressure.
    Feb 2008
    I had the fuse pulled because the self test thing was frustrating me. I put it back in, checked all of the resistances for the sensors, and went about my day today with no light. I'm assuming that having the fuse pulled had something to do with the tire pressure light coming on. Actually, the self test hasn't been making as much noise as it used to, so maybe I re-secured one of the wires while checking the sensors, as well!!
  10. #10 Re: Check Tire Pressure light on with no low pressure.
    I live here. UR LOSN's Avatar
    Rockford, IL
    my GT has this problem as well. kind of annoying.....
  11. #11 Re: Check Tire Pressure light on with no low pressure.
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    I have a 97 GTP as well.... I was stuck on the same issue...
    I disconnected my front two wheel speed sensors, cleaned them up a little, and re-connected them.... lights went off and stayed off.
    also - I like that my 97 doesn't have traction control
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  12. #12 Re: Check Tire Pressure light on with no low pressure.
    PA
    Quote Originally Posted by GreenNirvana101 View Post
    Just remember that it does have torque management though. That is just as bad sometimes.
    2001 GSE
  13. #13 Re: Check Tire Pressure light on with no low pressure.
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    GTP has a check tire pressure light?!?!?! No way! Where is it?..(by the rpm gauge?) <--- Noob here
    It took me 2 weeks to find out I had a cig lighter in the car. I was amazed.
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  14. #14 Re: Check Tire Pressure light on with no low pressure.
    Feb 2008
    Mine's in the DIC on the right side.
    Correction to my earlier statement that I believe I fixed the light issue: It came on twice today while I was driving around. Along with the Check Tire Pres. light came the ABS light, so I'm guessing I have a wheel speed sensor going out or shorting itself out on the chassis somewhere. Anyone have an ABS scanner they're willing to loan me??
  15. #15 Re: Check Tire Pressure light on with no low pressure.
    PA
    Yes, sounds like you have a WSS going bad and need to replace the hub. That would be my guess. Could be a bad wire in the connector harness. But like you mentioned, you need to get a scanner to narrow it down to a particular wheel.
    2001 GSE
  16. #16 Re: Check Tire Pressure light on with no low pressure.
    Feb 2008
    Will any computer-based scanner work, or do I need an ABS specific scanner to catch the code?
  17. #17 Re: Check Tire Pressure light on with no low pressure.
    PA
    You need a scanner that specifically does ABS codes. I have a scanner for OBD-II codes, but it will not do ABS codes. I also have a PowrTuner PCM tunning package that can scan and delete codes, and this also does not scan or delete ABS codes.
    I was lucky enough to borrow a Snap-On scanner that could do the ABS codes when my ABS light was giving me trouble. Most garages have something similar to this.
    2001 GSE
  18. #18 Re: Check Tire Pressure light on with no low pressure.
    Saraland Alabama
    on my '97 it's on the drivers knee bolster (the panel under the column)
  19. #19 Re: Check Tire Pressure light on with no low pressure.
    PA
    Quote Originally Posted by LilAbner View Post
    Hi,
    Where exactly is the reset button?
    Thanks
    Quote Originally Posted by archemedes View Post
    Posted right above ya...
    2001 GSE
  1. Fuel pressure gauges
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-28-2008, 08:03 PM
  2. Tire Pressure System not working.
    By xray328 in forum General Tech Discussion
    Last Post: 05-13-2008, 08:43 AM
  3. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
  4. Pressure Supply Fuel Line
    Last Post: 03-26-2008, 10:08 PM
  5. After Market Fuel Pressure Regulator
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 02:14 PM
