Thread: no a/c, no heat, no blower, key stuck
Results 1 to 3 of 3
  1. #1 no a/c, no heat, no blower, key stuck
    canada
    Im sure this problem has been covered here before, but I am a newbie. Here is the problem, my a/c used to work on 5, dead from 1-4, then it died on 5. I just changed the blower resistor, and still no a/c no heat, no nothing. When I drive I can feel the slightest cold air coming from the vents, but when I come to a stop there is nothing. Also my key is stuck in the ignition, so I have to do the manual way of getting my key out and push the little tab in the steering column to get the key out. As well, my shifter gets stuck in park, so once again I have to to it the manual way, and push on the safety lock thing in order to get the shifter out of park. Everything else on the electrical system works, the drl dont go out when the a/c setting are on 1-4, rear defroster works, all windows roll down, everything else works. Any help or ideas would be much appreciated, thanx for your time. I should add, i checked all the fuses, and they are all good. Oh yeah by the way, its a 2002 GT
  2. #2 Re: no a/c, no heat, no blower, key stuck
    Feb 2008
    Check power to the blower motor. The motor itself may be dead, or the switch on the dash may be dead.
    Double check the fuses, Specifically the BTSI fuse in the cabin fuse panel. It's failure is known to cause the key issues you have.
    Also, you may have to remove/replace the key lock solenoid entirely. I had the same problem with my key and shifter and it all went away when I removed the solenoid from the steering column.
  3. #3 Re: no a/c, no heat, no blower, key stuck
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    welcome to GPF. you're right, this has been covered. see the search at the top? use it...
    it's the ignition switch.
  1. 04+ HUD is stuck...
    By PonchoDvr4Lfe in forum General Tech Discussion
    Last Post: 02-22-2012, 01:55 PM
  2. oh its stuck
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-17-2010, 06:50 AM
  3. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
  4. replaced new blower resistor and still no heat
    By nemesis in forum General Tech Discussion
    Last Post: 11-02-2008, 12:29 AM
