What kind of supercharger is on 2004 gtp?
The goodish one
Where is the best place to get a gasket for the m90 supercharger?
what is all that stuff about L32 and L67?
what one do i need?
Local parts place would be faster and probably cheaper than ZZP.
$17 here for the gasket and the two o rings.... which you have to purchase separately from ZZP.
And I'm in canada so ****s more expensive here...
And it looks like L32 S/c gaskets are ****ed.
Still check with your local parts store to see if its worth waiting on ZZP.
yeah i called local stores and the only place they have them at is sturdevants and they want 63 bucks!!! screw that!!
^^Agreed. You need to ask them for the intake PLENUM gasket. Should be part #MS96789 at ORiellys. Then again...the GenV is a metal gasket and your also paying for the TB gasket, PCV Valve gasket...etc. It does sound a bit pricey but you have to figure since you've got a GenV car...its is a tad more expensive. The GenIII gasket however is $9.99...and you might be able to cut it to match the GenV one if you want to go about it that route...but I'm not guaranteeing that to work. It is part #MS95744
