Thread: Should I put my tb screen back on?
Results 1 to 13 of 13
  1. #1 Should I put my tb screen back on?
    MA
    I took it off when I was putting my open cone intake on. Also if I put it back on will it effect my performance?
  2. #2 Re: Should I put my tb screen back on?
    Donating Users Tengis's Avatar
    Houston
    Id put it back on. Ive seen MAF inconsistencies with descreened throttle bodies on probably a dozen cars.
    This is completely different given Ive got a turbo of course but my car will barely run without one because of the turbulent air.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  3. #3 Re: Should I put my tb screen back on?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    yeah just put it back on. I didn't have one for the longest time and the car idled kinda rough. Put it back in and it was fine
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  4. #4 Re: Should I put my tb screen back on?
    Charles City, IA
    Yeah put it back in.
    SMGPFC Two Nipple General
  5. #5 Re: Should I put my tb screen back on?
    Some cars will actually start idling like dog sh1t with them out. If your car doesn't like mine didn't...its hit and miss.
  6. #6 Re: Should I put my tb screen back on?
    MA
    Will it hurt the cars performance
  7. #7 Re: Should I put my tb screen back on?
    It is likely f'ing the tune up badly. The screen is to direct air across the maf sensor. If the pcm is programmed to read the air a certain way and you change that, you should retune the car for the change. Doesn't appear that you have done that.
    Check your fuel trims and O2 readings. The car may feel a heck of a lot faster, running lean will make it faster and much easier to do damage to the pistons etc.
  8. #8 Re: Should I put my tb screen back on?
    MA
    Do you mean it will feel faster with it off? Anyways I put it back on and my car runs much better.
  9. #9 Re: Should I put my tb screen back on?
    Yup, it can feel/be faster w/o the screen. That's because it's leaning out the mix and causing it to run on the edge of troubles.
  10. #10 Re: Should I put my tb screen back on?
    MA
    That was not the case for my car haha, it car would bog down at launch I put it back on and no more bogging
  11. #11 Re: Should I put my tb screen back on?
    LEAN is MEAN
  12. #12 Re: Should I put my tb screen back on?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I took it off, didn't notice any difference at all after a few days, I broke the screen while trying o put it back on...
  13. #13 Re: Should I put my tb screen back on?
    MA
    Quote Originally Posted by Juanmiguel View Post
    I heard it does not affect some cars, but it really screwed with my car. When i put it back on the car ran 100x better.
  1. MAF Screen
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 08:21 PM
  2. Dvd/gps screen help
    By MrBoges in forum Audio, Security & Visual Electronics
    Last Post: 06-30-2009, 05:19 PM
  3. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  4. TB Screen
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2008, 10:55 AM
