Thread: Radiator fan on 96 GP won't work
Results 1 to 6 of 6
  1. #1 Re: Radiator fan on 96 GP won't work
    May 2008
    If you think it's a great idea to have your computer only turn on your fan in traffic at 230 degrees, by all means, leave you car the way it is and enjoy your toasty engine in traffic.
    If you know about the wiring on these cars, you'd know that the computer does not check the temperature of the coolant in the radiator, the factory thermal switch is in the block. I left that switch and wiring intact so the computer still knows what the temp of the coolant in the block is. I just set up a parallel system to keep the engine cooler in traffiic than the 230 degrees the factory intended.
    Boatman.
  2. #2 Re: Radiator fan on 96 GP won't work
    Barksdale AFB, LA
    Quote Originally Posted by Boatman View Post
    I never said what they had it set to was a good idea, just that it's a good idea to have the computer control and monitor it.
    Yes, I know that, and it's how it should be.
    I wasn't playing down your solution. You asked "Why the thermal switch goes into the computer and not the fan relay I also have no idea," and I gave you the answer.
    2009 Subaru Impreza WRX STI
  1. ZZP oversized radiator, link to the cheaper ones on Ebay?
    By Tengis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2008, 06:47 AM
  2. Radiator Hose Diameter
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 05-20-2008, 03:01 PM
  3. Intercooler radiator
    By silvermistGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 12:29 PM
  4. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
