could be an ignition switch start at the top of the circuit and work your way down untill you loose power.
PNP switch... i guess you mean the neutral switch.. yes i have replaced it
it is located on top of the transmission
Well , i only the last thing to check is the ignition switch,but it is kind of hard to get it out. And i am not really sure after i get it out what to do and how to test it.
Not sure if its the switch by itself or the wiring
Any ideas or recommendations what to when i take it out?!?
Thanks
