Anyone know how to do this? i think it would be a fun project and a neat mod.!!!!!
you mean the button you can find at places like pepboys? it would be a cool mod, i like having my interior stock but for someone who races it would put a more racecar feel into the drivers hands
A clean set up push button would be cool nothing tacky It would have to look stock for me to want it
all youd have to do is cut the wire in the ignition collum and wire in the switch with a relay. you could also just tap into the wire, so you could start the car either way. youd still need the key in the ACC spot, but then hit the button and go.
this should help, this was drawn my a guy on my other forum
if i had to use the key it would be extra work and look tacky IMO
This is what i would do. They are found on newer nissans, bmws, lexus etc. They are cool IMO and eliminate some hassles with the ignition switch.
StarDrive - Push Button Ignition System
that would be sweet, and oh ya that car fits her really well
That StarDrive is pretty cool. I've used it on the Vettes when i worked at a Chevy Dealer. My question is what do you do with the key area on the column. If a person could remove it and put in some kinda block off plate that would be cool.
i would think with a couple colum peices a bock off could be fitted with out issue
Pull out the ignition cylinder and then put the star drive thing there.
but with the startdrive, it says that it's not easy to use with a mechanical steering wheel lock and would have to be removed; so wouldnt that mean that it wouldn't work for GPs since our steering wheels lock?
what year of car are you wanting to do this on? if you have a transponder key(pk3 on the shaft) it complicates things a little. if you want send me the year of your car if its equipped with a transponder key and an e-mail address and i can draw you a schematic on how to make this work with a toggle switch and push button
price on the nissan piece woahhh, i have intelligent key for my sts and i have gotten to use to having no keys, i think im gonna do my gtp the same way. and i guess i'll have to spend almost 500 to do it lol
Silver2kgtp also has a push button start set up.
