Thread: Tire Pressure System not working.
Results 1 to 3 of 3
  1. #1 Tire Pressure System not working.
    May 2008
    I recently bought an '04 GTP and I don't think the tire pressure system is working.
    I filled up all the tires to the same psi then drove around for a few days. I then reduced the air pressure on one tire to 15 psi and nothing happened. (no bells or whistles)
    Any ideas?
  2. #2 Re: Tire Pressure System not working.
    St. Louis Mo.
    You bought it used I am guessing? Did you buy it from a Pontiac dealer or what? If it is used, was it modified in any? There could be a couple possibilities here. One the previous owner disabled it, or two possibly check the fuse box that controls that feature to insure the fuse is not blown or missing perhaps? I am not sure if that is something in the PCM that can be disabled or enabled, but that is also worth looking into. And if you got it from a GM dealer, I would haul it back there and pitch a ***** if all else fails
    Just a couple thoughts on that.
    James Shafer
    St. Louis MO
  3. #3 Re: Tire Pressure System not working.
    Barksdale AFB, LA
    Is your system the kind that uses valve stem pressure sensor, or wheel speed sensors (poor man's system). Mine uses the latter and goes off with repeatable results (and without my intention one time) at exactly 10PSI lower than the rest.
    2009 Subaru Impreza WRX STI
  1. New transmission not working correct - possible PCM issue?
    By knightmastery in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-31-2008, 05:13 AM
  2. DIC working?
    By Seagya in forum General Tech Discussion
    Last Post: 05-13-2008, 07:20 AM
  3. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
  4. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
  5. gauges not working?
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-13-2008, 12:11 AM
