Thread: Car bogging down at launch and dieing
Results 1 to 13 of 13
  1. #1 Car bogging down at launch and dieing
    MA
    Ok so friday I made an open cone intake and everything was good until today when at a stop sign my rpms go down to zero and the engine shuts off. Also my car is bogging badly when I floor it and it will barly screech the tires. Has this ever happened to anyone who installed an open cone intake and if not does anyone have an idea what might be causing it.
  2. #2 Re: Car bogging down at launch and dieing
    sound like you CPS is going bad and you maf might be dirty or bad
  3. #3 Re: Car bogging down at launch and dieing
    MA
    What is a cps haha? Also could it be a problem with the intake not being on there secure enough
  4. #4 Re: Car bogging down at launch and dieing
    crank position sensor, that can cause the rpm to drop to zero and then the car can stall.
    intake should not be the problem, another Question did you remove that honeycome thing in the intake that sit in the thottle body?
    if you did put it back in.
  5. #5 Re: Car bogging down at launch and dieing
    MA
    Yes, but stupidly I threw it out do u know where I could pick one up?
  6. #6 Re: Car bogging down at launch and dieing
    MA
    Also how much would a new cps and new maf cost?
  7. #7 Re: Car bogging down at launch and dieing
    this will work on all 97-03 grand prix: 2002 Pontiac Grand Prix Crank Sensor 3.8L Supercharged: eBay Motors (item 310240664943 end time Sep-10-10 07:07:55 PDT)
    for the maf, unplug it first to see if the car acts different, if it does then its bad.
    ZZP sells the TB screen, or maybe post up a wanted ad to see if anybosy has one.
  8. #8 Re: Car bogging down at launch and dieing
    MA
    How will the car act different?
  9. #9 Re: Car bogging down at launch and dieing
    yeah you will notice it, have the car running and unplug the sensor, the rpms should jump a little and if you drive it will act funny.
    but if the rpms dont do anything or it dont change them the maf is bad,
    and the TB screen can cause jumpy idle aswell
  10. #10 Re: Car bogging down at launch and dieing
    MA
    One more question is the maf located on the side of the tb?
  11. #11 Re: Car bogging down at launch and dieing
    BAM
  12. #12 Re: Car bogging down at launch and dieing
    if you unplug the MAF and the car runs better then its a MAF problem. its possible that you pulling the screen out is screwing up the car as well.
  13. #13 Re: Car bogging down at launch and dieing
    MA
    I thought the screen removel would onlh make the rpms jump not cause the car to die and bog down. Once work is over I am gonna try to unplugg the maf
  1. car bogging down :(
    By Ricky21 in forum General Tech Discussion
    Last Post: 08-19-2010, 12:55 AM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. Help GT keeps dieing and grinds when starting and running!!
    By Panto911 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2009, 11:22 PM
  4. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
  5. Random dieing at idle + occasional misfire = me pissed off
    By mark455 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 09:22 PM
