Thread: ? If Hot could have a smell 97 GTP
Results 1 to 5 of 5
  1. #1 Re: ? If Hot could have a smell 97 GTP
  2. #2 Re: ? If Hot could have a smell 97 GTP
    Denver
    Not only that - when you park your car (and turn it off) you get heat soak. The case iron block has a huge heat capacity.
    Heat is added to the block via the combustion chamber and removed via the coolant (and eventually out to ambient via the radiator). When you park and the water pump is no longer spinning, the motor temperature will rise quite a bit. This is why theere is a warning sticker about the fan spontaneously turning on when the car is off (to counteract this effect).
    Also - if you've recently cleaned your engine or had it cleaned, you might be smelling the fumes of the cleaning chemicals burning off.
  3. #3 Re: ? If Hot could have a smell 97 GTP
    Is the engine overly dirty? Do you smell a rotten egg type smell?
  1. Odd smell from engine bay
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 08-14-2009, 02:27 PM
  2. Normal Oil smell?
    By xerxescct in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:45 PM
  3. Bad Smell
    By GMPUNK in forum General Tech Discussion
    Last Post: 07-08-2009, 04:50 PM
  4. whats this smell?
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-17-2009, 03:06 PM
  5. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
