Thread: Gen 3 M90 pulley size VS. Gen 5 M90 Pulley
Results 1 to 4 of 4
  1. #1 Gen 3 M90 pulley size VS. Gen 5 M90 Pulley
    Minnesota
    If a Gen 3 M90 is running a 3.4 pulley and the Gen 5 M90 is more efficient. What would the 3.4 equivalent pulley be on a Gen 5 M90? Would it be a 3.6?
  2. #2 Re: Gen 3 M90 pulley size VS. Gen 5 M90 Pulley
    Jersey
    yeah, something like that
    16' wrx sti- stock
  3. #3 Re: Gen 3 M90 pulley size VS. Gen 5 M90 Pulley
    MA
    i believe that for the most part you add .2 to the gen3 pulley size and come out with the gen v. sooo...
    gen 3 gen v
    3.4 3.6
    3.2 3.4
    im not sure if it is true across the board but yes the gen3's 3.4 is roughly equivelant to the genv's 3.6
    SMGPFC Member #9
  4. #4 Re: Gen 3 M90 pulley size VS. Gen 5 M90 Pulley
    oooooooooooooooooooooooohhh...I've typed this a few times...here goes.
    The reason people upgrade from the GenIII to the GenV is a couple reasons...one being efficiency...you can get away with smaller pulleys on a GenIII but your yanking more power off of the motor to do so...where as the GenV...you can make the same power with a larger pulley and take less power off the motor to do so. The other reason being the rotors never flake apart from what I've seen...GM skimped on the GenIII's and it shows...the coating on the GenV's rotors are tits. The inlet to the GenV also doesn't "ramp" up like the GenIII's do...so you don't have to worry about the air having to run up to get to the rotors...guess you could call it an obstruction. Typical rule of thumb...I don't really say .2"...because some people will have different results. I will say that most 3.4"/3.25" setup GenIII cars are the same on GenV cars with a 3.6"/3.4" setup. You've just gotta mod more to drop pulleys on the GenV's. Also...according to Eaton...anything lower than a 2.8" on a GenV makes it spin WAY too much...causing a big break in inefficiency...only thing I would do...if you were GenIII and just kept running down in pulley sizes is this...when you get to a 2.55" on a GenIII, go to a 2.8" GenV...and be happy.
    Hope this helps.
  1. help with pulley size?
    By benblank in forum 04+ Specifics
    Last Post: 03-19-2010, 12:24 AM
  2. pulley size
    By hollis1 in forum Introductions/Noob Questions
    Last Post: 12-16-2009, 12:14 PM
  3. need some help with pulley size
    By mack1212 in forum General Tech Discussion
    Last Post: 04-01-2009, 08:11 AM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
