Thread: Why is my MAP sensor causing my car not to start?
Results 1 to 8 of 8
  1. #1 Re: Why is my MAP sensor causing my car not to start?
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    The car did start if I capped off the MAP sensor and TB line. So IDK what that means. I also happened to find that there was a slight crack in the rubber vac line piece directly off the TB. Can a vac leak cause a car not to start?
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  2. #2 Re: Why is my MAP sensor causing my car not to start?
    Barksdale AFB, LA
    Quote Originally Posted by 1998gpgt View Post
    Could it be that the PCM adusted itself to the L67 MAP, and the L36 MAP is throwing things off ?
    No, it didn't just "adjust itself".
    Quote Originally Posted by VinnieGTP View Post
    The MAP needs to come off the port under the snout on th LIM.
    Not if his PCM is still basically for an L36. It would throw off its readings, especially since that MAP isn't designed to see boost.
    Ask anyone who ever accidentally left that piece off when working on their car. It doesn't start.
    You can't trouble shoot your car properly with other known issues. Fix the leak and we can go from there.
    2009 Subaru Impreza WRX STI
  1. Hesitation causing poor gas mileage
    By elriqo28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2008, 12:23 PM
  2. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
  3. AC compressor is causing my RPM to surge?
    By JCGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 01:48 PM
  4. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
