Thread: Fan speed switch
Results 1 to 11 of 11
  1. #1 Fan speed switch
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Every speed on the A/C fan selector works except for speed 1.. any ideas why it does that?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Fan speed switch
    SE Level Member GothTP's Avatar
    Hollywood, FL
    same thing here, it works on 2,3,4 and 5 but not on 1. I went to the junk yard to replace the control switch but it kept doing the same thing. I guess is something in the blower.
  3. #3 Re: Fan speed switch
    Wilkes Barre, PA
    normally it dosent bother me but when im on the highway speed 2 will be too much sometimes and i want 1.. o well cant have everything lol
  4. #4 Re: Fan speed switch
    May 2008
    staten island,NY
    done and done
    ZZ Performance
  5. #5 Re: Fan speed switch
    Willoughby, Ohio
    yep, blower motor resistor is bad, you will keep losing speeds until you have none
  6. #6 Re: Fan speed switch
    Hollywood, FL
    yes, sometimes, specially at night, 2 is too much, I have to switch from max ac to normal ac.
    do you know how to fix that? is it something complicated?
  7. #7 Re: Fan speed switch
    GT Level Member Lvgrandprix2003's Avatar
    Cincinnati
    Fan resistor switch is under the dash next to the blower motor. Its a pain to get to but you can do it. You have to take the bottom cover off under the dash and you will see the blower motor. The resistor will be right next to the motor. Do your self a favor and get a 1/4" universal, and just pull the motor first. The Resistor will be easier to pull. I laid my seat down as far as it would go and just laid on my back and did it. Its a hell of a head rush
  8. #8 Re: Fan speed switch
    Hollywood, FL
    Thanks, I will be out of the state for a week so I will plan to do the job next weekend I will keep you posted about the results.
    Here is a nice tutorial I found hope it can help: Ontario Quebec Club Grand Prix :: Fan resistor replacement
  9. #9 Re: Fan speed switch
    SE Level Member TomOfTarsus's Avatar
    Nov 2009
    near Pittsburgh, PA
    Wow, I forgot I have this problem, too! I got on because my vent selector switch is broken - it feels like a physical disconnect, but anyway I can't choose between dash vents, defrost, etc., and the air conditioner light is always on. So I'm going to keep searching, but if anybodyu has a link to the correct thread, I appreciate it!
  10. #10 Re: Fan speed switch
    Tom..I'm pretty sure that's actuator controlled.
  11. #11 Re: Fan speed switch
    Nov 2009
    near Pittsburgh, PA
    Thank you, sir. So I have left/right temperature door actuators, and then an actuator for door(s) directing air to defrost, mid-cabin, and/or floorboard area, etc? I wonder why the a/c light is always on now? The system must be stuck in either a "max" or defrost position, which forces the a/c on.
    I went through about 8 pages of the how-to section and couldn't find a thread... so thanks again, not meaning to threadjack.
    Tom
  1. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  2. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. Top Speed of GTP
    By robahr24 in forum General Tech Discussion
    Last Post: 08-21-2008, 03:00 PM
  5. Need for Speed
    By BKA05GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2008, 04:29 PM
