Thread: Cam sensor help
Results 1 to 3 of 3
  1. #1 Cam sensor help
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Just picked up another Gp GT 48,000 mile 2 door in white for 800 bucks!!!!
    Kid sold it to me cheap because it needs a cam sensor and of course a case learn done, along with some minor maint. the dealership wanted 2200$ to do all repairs, so I bought it. question is where is the sensor at? someone said to remove p.s. pump and its right there. Any insight would be appeciated.
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  2. #2 Re: Cam sensor help
    Apr 2009
    stockton ca
    remove the power steering pump pulley and its there its only a 20 min job and a 40$
    My guess is its the interupter magnet inside the timing cover on the cam gear
    For that things get more time consuming and expensive
    remove all the stuff down to the cover and pull the front cover and bam
    is right there
    best bet would be to find out for sure Or just tear it down and replace the interupter the cam sensor and the crank sensor and might aswell toss a new timing set in it while your at it
  3. #3 Re: Cam sensor help
    Thanks for the info, gonna scan it later and go from there.
    98 GTP Stock
  1. MAF Sensor
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2010, 01:44 PM
  2. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  3. O2 sensor after cat
    By monsterjam5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 03:03 AM
  4. MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 02:57 AM
