Thread: k i got a cylinder 4 miss and im running out of options
Results 1 to 20 of 36
  1. #1 k i got a cylinder 4 miss and im running out of options
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    ive got a putt putt sound out the exhaust and a little shake of the engine. found out its a cylinder 4 miss. replaced all plugs with double plat autolites and new wires. checked my coils and ign. control module they all test fine. its got a 6 month old crank sensor that was replaced by me and my friend at midas. k so ive narrowed it down to either an injector or maybe bad compression. i havent done a noid test on the injector but i did use a stethiscope and it is pulsing steady just like the other five. thats about all i have... what else can i do here? im also thinking a vac leak but... its a 2000 gtp
    2000 Daytona GTP(aka the slow fwd GTO)
  2. #2 Re: k i got a cylinder 4 miss and im running out of options
    Apr 2009
    stockton ca
    do a comprssion test and see where all cylinders are at
  3. #3 Re: k i got a cylinder 4 miss and im running out of options
    Hagerstown,Md
    swap the injector and see if the miss follows
  4. #4 Re: k i got a cylinder 4 miss and im running out of options
    Charles City, IA
    Also swap the coils around, just because they test good does not mean they are good.
    SMGPFC Two Nipple General
  5. #5 Re: k i got a cylinder 4 miss and im running out of options
    Nov 2009
    Michigantown, IN
    awesome. ill do all that. as for the injectors... will i have to get new o rings when i pull em out or can i just remove and pop back in?... im worried i might ruin the o rings while takin em out.
  6. #6 Re: k i got a cylinder 4 miss and im running out of options
    depends how old they are.
  7. #7 Re: k i got a cylinder 4 miss and im running out of options
    Charles City, IA
    Autozone has injector 0-rings in the help section if you tear some.
  8. #8 Re: k i got a cylinder 4 miss and im running out of options
    Nov 2009
    Michigantown, IN
    k heres whats weird. during this whole thing my ses light never came on and even more odd was the fact that my scanner at work didnt read any codes, however, the one at autozone did. theirs does look way newer and it also reads abs lights... and of course the scanner at midas found the code for the cyl. 4 miss. well i went and switched the coils and then on the way home boom... my ses light came on...lol. so tommorow ill find out what it says. this time it should read a cyl. 2 miss since thats the coil i traded. if it does then ive got a winner...
  9. #9 Re: k i got a cylinder 4 miss and im running out of options
    Jul 2010
    bettendorf ia
    if you know some one with a good scanner. you can shut the injector off on the cyl and see if it changes the way it runs.
  10. #10 Re: k i got a cylinder 4 miss and im running out of options
    if you wanted to do that you could simply unplug them...
  11. #11 Re: k i got a cylinder 4 miss and im running out of options
    Nov 2009
    Michigantown, IN
    yeah but if i can hear the injector pulsing cant i assume that its fine. its quite possible its in my head maybe i do have a small exhaust leak at the rear manifold apparently. heres what happened with the scanner my friend has which is like a 2k dollar scanner. at idle im reading a good deal of misfire at cyl 4. when i raise the rpm to about 3k the miss pretty much goes away and then i get very small random misses in a couple other cylinders but mainly at idle til 3k rpm its cylinder 4. the coils are fine. ign mod is fine. the only other option i have is a compression test and maybe a fuel pressure test.
  12. #12 Re: k i got a cylinder 4 miss and im running out of options
    Jul 2010
    bettendorf ia
    i would check fuel pressure.
  13. #13 Re: k i got a cylinder 4 miss and im running out of options
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    Not to pull up a old thread but I'm having same issue with same cyl. What did it end up being? I replaced all coil packs plugs and wires. Injector checked out fine, I did have low fuel pressure but changed pump and regulator and still have misfire
  14. #14 Re: k i got a cylinder 4 miss and im running out of options
    hows your exhaust?
  15. #15 Re: k i got a cylinder 4 miss and im running out of options
    Brookfield, IL
    Brand new 3inch catless downpipe, brand new resonator, and flowmasters. Less then 1000 miles on all of it. Got a zzp pcm to delete and change out codes for catless dp
  16. #16 Re: k i got a cylinder 4 miss and im running out of options
    sure the DP isn't leaking at the top?
  17. #17 Re: k i got a cylinder 4 miss and im running out of options
    Brookfield, IL
    Downpipe is tight, I'm seeing the misfire on my aeroforce. Its only at idle any throttle at all its fine, real bad right at start up
  18. #18 Re: k i got a cylinder 4 miss and im running out of options
    And you've tried the standard set?
    Coils, plugs, wires, moving injectors, ICM, exhaust leaks?
  19. #19 Re: k i got a cylinder 4 miss and im running out of options
    Brookfield, IL
    Only thing I haven't done is switch around injectors. All plugs wires and coil packs brand new
  20. #20 Re: k i got a cylinder 4 miss and im running out of options
    these cars misfire at idle. if its not causing any problems and all the ignition goodies are fine then who cares. my car always misfired at idle.
  1. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  2. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  3. MY GP running like a 4 cylinder car why?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-14-2009, 07:04 PM
  4. I miss my LT1
    By Black18Ice in forum Off Topic Discussion
    Last Post: 10-01-2009, 11:07 PM
  5. I have a miss. :(
    By Doug_Guilds in forum General Tech Discussion
    Last Post: 09-09-2008, 07:19 PM
