I finally bit the bullet and got the RA headlights. Pictures are here.
My observations:
  • They included new bulbs. I wasn't expecting this.
  • They're a perfect fit.
  • The adjusting screws are made of pot metal. The OEM adjuster screws use a Torx bit and are high carbon steel. These are a phillips head that will strip the first time you use them. But...a 1/4" socket fits the outside of the adjuster screw and you can adjust per normal procedure.
  • Made in Taiwan (the ones I got).
All in all, I'm very impressed. I was a little pissed with the crappy adjuster screws. Then I remembered that I paid $36/ea. This is less than 1/2 of a USED headlight assembly from an auto recycler.
I would definitely recommend these to pretty much anyone. As you can see, my old headlights were pretty well trashed. The pics you see in the gallery are with a clean car, and after I've used the headlight restoration kit (I've sanded and polished the crap out of my old lenes - they're still pretty worthless).
Time will tell how well these hold up. But, for the price, I can't be too critical.
