Thread: 4psi!! help!!
Results 1 to 20 of 32
  1. #1 Re: 4psi!! help!!
    is everyone in this thread serious? how has no one mentioned that when the BBV solenoid is active that the car is limited to 4-5 pounds of boost? this 100% sounds like your BBV is acting up.
  2. #2 Re: 4psi!! help!!
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I was going to, but he pulled both vac lines off the actuator, effectively shutting the BBV completely, and didn't notice a difference.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: 4psi!! help!!
    SE Level Member iluvbst's Avatar
    kissimmee,fl
    ive been waiting for you to come to my thread...seems like you know alot about these beast...so if the bbv is bad, why when i unplug both vac hoses, i still get 4-5 psi..more like 4. but the only difference as i said before is the sc sounds be whiny,like i can hear it more...i also just took the belt off, have a bad coupler, would that cause this?
