Thread: will this bolt right in?
Results 1 to 5 of 5
  1. #1 will this bolt right in?
    Joliet, IL
    can i pull my steering column out and put this one right in? how much of a PITA would this be? i have passkey disabled in my car btw so that wouldnt be an issue.
    04 05 06 07 Grand Prix Steering Column Wheel (E90021) : eBay Motors (item 380133378105 end time May-19-10 15:03:06 PDT)
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: will this bolt right in?
    Charles City, IA
    How did you disable the passkey system?
    SMGPFC Two Nipple General
  3. #3 Re: will this bolt right in?
    Joliet, IL
    get the key copied at ace and take apart the column then duct tape the key to the sensor box.....the sensor in the key is close enough to the sensor in the box and it thinks your inserting the real key only do this if your alarm has a starter kill other wise your car is hot wire friendly. better than a 50$ bypass module IMO
    00 Silvermist GTP
  4. #4 Re: will this bolt right in?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by BoostJunki3 View Post
    i had to do the same thing when my remote starter quit transmitting the signal from its key to the ignition...
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  5. #5 Re: will this bolt right in?
    SE Level Member beezer34ca's Avatar
    Morden, MB
    I would like to do the same thing. Did you figure out if it will work? The newer steering wheel with paddle shifters would be awesome to have in my 2000 GTP.
  1. Need to know bolt sizes
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 08:32 PM
  2. GXP vs GP Bolt Patttern
    By BigBoy2 in forum 5.3L V8 (LS4)
    Last Post: 03-01-2010, 01:19 PM
  3. bolt pattern
    By jprovinsal in forum Tires & Wheels
    Last Post: 05-13-2009, 04:13 PM
  4. Bolt Ons?
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-03-2008, 10:06 PM
