Thread: Can u make your supercharger louder without an intake?
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 121
  1. #1 Re: Can u make your supercharger louder without an intake?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    Quote Originally Posted by 40th GP View Post
    Pictures would be great--I am a noob with these cars. I have always been into turbo buicks before this. Just got it a few weeks ago and trying to get it in top shape.
    I don't really know what is the inlet or the outlet, so if you have pics showing this and where to carve that would be really helpful. What are the shorter bolts I would need? Do I need to get the oil at the dealer--can't get it at autozone or somewhere? I don't need to tune or cause tuning problems if I only do the supercharger without the throttle body?
    Thanks again.
    correct on tune and correct on oil only at dealer of zzp lookin gfor pics now of sc if anything give me an hour and ill pull min eout of the garge and post pics of new and old so you can see but it may take a while...thinkin of starting a thread on porting in the diy section
  2. #2 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    and a thanks or two would be nice all that typing made my hands hurt
  3. #3 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    before i smoothed it out.....throttle body.....open up and say ahhhhhhhh...u can see where i had to epoxy doing this will cause a small hole to open up in the maf area of the throttle body...use jb weld to seal it up on the inside and outside of the throttle body and then port the estra away 24 hours later
  4. #4 Re: Can u make your supercharger louder without an intake?
    Its been typed too many times before for me to thank you for it
  5. #5 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    lol at matt i gave u a thanks
  6. #6 Re: Can u make your supercharger louder without an intake?
    GT Level Member 40th GP's Avatar
    Utah
    I have seen some posts on porting and how to enlarge the triangle and remove the humps, but what are the bolts you are talking about? I also don't know which is the inlet or the outlet (I don't have it off yet and have never had a blower before). An hour or so would be great. I am not tearing into it until Friday. I will be doing the LIM and figured I might as well do this while in there.
  7. #7 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    the humps at the bottom of the traingle are there cause two bolts go through them to hold the snout and rotor plate...when u remove the humps the bolts will still stick out there the humps use to be so you will cut down the effectiveness of the port if the bolts arent shorter
  8. #8 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    inlet after port sorry about my gasket still hangin there but you get the idea
    unported intake for the sc...u can see the rough surface and the groove i mentioned
  9. #9 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    ported on right this is the discharge for the supercharger
  10. #10 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    needle bearings inside supercharger...u dont want metal in these so protect them with tape or rags the end of the rotors fit into these
  11. #11 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    ported on top...discharge of the lim u can see that the top is opened....use your old lim gasket and gastet match/smooth these to duplicate holes in gaskets
  12. #12 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    intake of lim...ported on right this time...remove the extra metal...get a grinder for this as its a ton of metal. if you do this you will also need to cut your gaskets to match. some people recommend smoothing out the bottoms on these pics but i honestly see little benefit but i may be wrong
  13. #13 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    rotor pack far right is what goes into the needle bearings..left hand side is the plate..this is what bolts between the snout and the sc casing
  14. #14 Re: Can u make your supercharger louder without an intake?
    Milwaukee
    ^holy bare rotors...
  15. #15 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    Quote Originally Posted by MrClean View Post
    these went from great lookin rotors to looking like this in a month of meth use(27 days and 467 miles)....some say meth wont hurt your car.....i let the pic speak for itself
  16. #16 Re: Can u make your supercharger louder without an intake?
    Utah
    I have seen some posts that you shouldn't port the intake manifold unless you are intercooled. Is that the case or is that fine on an unmodded car too? Will I also need a gasket if I pull the snout, or does it just go back together? On the inlet, do you just hog it out and smooth it over so the opening is as big as the inside? I am also not really seeing the groove.
  17. #17 Re: Can u make your supercharger louder without an intake?
    no point really. lim is fine till you get heads/intercooler
    snout is sealed with anerobic sealant
  18. #18 Re: Can u make your supercharger louder without an intake?
    Ocala, FL
    ^ Holy 10 posts in a row.
  19. #19 Re: Can u make your supercharger louder without an intake?
    Feb 2010
    somewhere cold
    Quote Originally Posted by codyAK View Post
    well if figured id show the new guy everything he needs to know at once lol
  20. #20 Re: Can u make your supercharger louder without an intake?
    Charles City, IA
    You coating was coming off anyways, METH WILL NOT HURT ROTORS THAT WHERE COATED RIGHT, the coating was coming off my stock ones before I even had meth, so I guess air eats the coating too.
    SMGPFC Two Nipple General
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
  2. make my own intake question
    By xsvtank in forum General Tech Discussion
    Last Post: 06-15-2010, 03:35 AM
  3. HOW TO: Make a heat shield for your intake
    By daveydavido in forum How To Write-Ups/Tech Tips
    Last Post: 04-05-2010, 12:07 AM
