Thread: ABS / Traction Issue
Results 1 to 4 of 4
  1. #1 ABS / Traction Issue
    Massachusetts
    Hi everyone,
    I was wondering if anyone has had issues with their ABS and traction lights coming on? I believe the computer that controls these is damaged according to my auto mechanic. Does anyone know what the best solution for repair would be? Im looking for something inexpensive if possible, If not I will just have the dealer replace it for me.... which means putting at least a grand into it.
  2. #2 Re: ABS / Traction Issue
    Nov 2009
    Platteville
    I have the same thing going on with mine. The lights come on intermittently. It could be a couple of things. First, one of my front rotors/pads had VERY uneven wear and causes a ticking noise when moving. Second, it could be the traction sensor on the hub. Both of these fixes are relatively cheap ($35 for a rotor or $20 for a sensor). I'd pull the wheels and take a look at your pads and rotors first and then make sure all of the hub sensors are connected correctly.
    **Note**: sensors are built into the hubs (i'm an idiot) so you need whole new hubs to fix the sensor--its packed in the bearing.
    Signature size too big, please resize and try again. - Management
    Bright Red 2001 Grand Prix GT w/ Thrasher CAI + 180* T-stat + AP104's + ZZP Wires + (Coming soon) ZZP Downpipe + Reprogrammed PCM
  3. #3 Re: ABS / Traction Issue
  4. #4 Re: ABS / Traction Issue
    Dallas
    I have the same problem, I started a thread today. I've replaced the wheel hubs twice. sent the computer to Module masters cleaned and replaced everything I can think of, no dice...
  1. ABS,Traction Controll, and Speed Sensors issue.
    By 02Prix in forum General Tech Discussion
    Last Post: 12-08-2010, 02:12 AM
  2. traction
    By m3ta77ica in forum Tires & Wheels
    Last Post: 10-24-2009, 02:06 PM
  3. 98 GTP Traction control issue- Experienced help please!!
    By Liquifire in forum General Tech Discussion
    Last Post: 07-10-2009, 02:19 AM
  4. Traction control issue?
    By NOVAZ27 in forum General Tech Discussion
    Last Post: 03-17-2009, 12:40 PM
  5. 2004 GTP traction control issue
    By bentendo92 in forum General Tech Discussion
    Last Post: 02-24-2009, 08:57 PM
