Thread: Wideband Bung Location
Results 1 to 4 of 4
  1. #1 Wideband Bung Location
    Donating Users
    South Deerfield, MA
    I'm going to pull my headers this weekend and put 2 bungs in. I'm going to move the one for the stock O2 a little bit so it isn't pointing right into the floor anymore and I'm going to put one in for a wideband. My question is this: Can they be one right after the other about an inch or two away from each other or would the second O2 get bad readings being right behind the other one? Thanks.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  2. #2 Re: Wideband Bung Location
    im not sure that id put them right next to one another unless they were on opposite sides of the pipe. i would definitely put more than a couple inches between them too.
  3. #3 Re: Wideband Bung Location
    Charles City, IA
    Mine is where the after cat 02 should be if you had a cat. Anywhere in front of the cat is ok.
    SMGPFC Two Nipple General
  4. #4 Re: Wideband Bung Location
    Donating Users
    South Deerfield, MA
    Thanks guys. I'll put the wideband bung further down the pipe. It will probably be easier that way to put it in and take it out when I need it for tuning.
  1. wideband o2 kit
    By popeyenate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 12:44 PM
  2. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
  3. O2 Bung plug
    By Sabrewings in forum General Tech Discussion
    Last Post: 05-30-2008, 12:31 PM
