Thread: front sway bar
Results 1 to 20 of 20
  1. #1 Re: front sway bar
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Gah! called the dealer, and not only do they not have any on hand (out of stock) --but apparently the oe stock bar is on nation wide backorder!
  2. #2 Re: front sway bar
    Wichita, KS
    Usually you want them to match by who ever makes them to keep the car balanced. But the GMPP one is not that BIG of a bar over stock so doubtful you will notice a big difference over a stock replacement unless you know how to drive your car through corners with handling in your mind.
    Gee...wonder why the fronts are back ordered for the W-Body's. Could it be the hundreds of cars that have cracked or split ends that are still out on the road today? Naaaa...GM makes great parts, this would never happen. LOL
    ~F~
  3. #3 Re: front sway bar
    SW Chicago Suburbs
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    i think i'll get one from Ed... hopefully it wont take too long to get here. i dont want to drive the car with it busted.
    hopefully its not too hard to change. i can do the work, methinks, but the little paranoid voice in my head says i might have problems
    will i be able to get to both bolts on each of the frame/cradle bushings without lowering the cradle??
  4. #4 Re: front sway bar
    Wichita, KS
    ^Oh ya, no problem.
    You may have to remove one front wheel to get it out. Pick your side some say remove it out the right, some say the left. Mine have always came out the nicest through the left wheel well on my car.
    Basic hand tools can get the job done no problem. Tops, one hour with running into snags, like working in the tight spaces if your a big guy. I put mine on jack stands too when I remove or replace them, other don't.
    ~F~
  5. #5 Re: front sway bar
    Barksdale AFB, LA
    I heard removing the rotor makes it a lot easier. Just gotta get the caliper and bracket off for that.
    2009 Subaru Impreza WRX STI
  6. #6 Re: front sway bar
    Wichita, KS
    WTH would you want to, or need to remove brake parts to get a sway bay out. Mine come close to that when I snake them out, but the bar never contacts the brake parts as to where they need to be removed. Some people like to do things the hard way, and most the time, the only way they know how.
    ~F~
  7. #7 Re: front sway bar
    Barksdale AFB, LA
    Like I said, it's what I heard. If I were to do it today, I would try it with that in mind. If I found it in the way, I'd take it off.
  1. SD front air dam what do you know about them.
    By Dohner in forum Visual/Body Modifications
    Last Post: 03-10-2010, 05:28 PM
  2. GXP front end?
    By shotgundust in forum Visual/Body Modifications
    Last Post: 04-06-2008, 01:02 AM
  3. Help with finding sway bars for 05
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 03-25-2008, 11:42 AM
