Thread: XPZ SETUP....and zzps thoughts
Results 1 to 2 of 2
shawn XPZ SETUP....and zzps thoughts 07-30-2010, 03:26 PM
noreasonwhyy Re: XPZ SETUP....and zzps... 07-30-2010, 05:19 PM
  1. #1 XPZ SETUP....and zzps thoughts
    Donating Users shawn's Avatar
    rogers arkansas
    I have some advice if your willing to hear it. Instead of Diamond pistons, I would pick up a 50k L36 shortblock and bolt all of your goodies on that. Then pick up OER lifters and set your lifter preload very closely. That will allow you to rev it to 6500-6700rpm. Your goal is to have about 12-13 psi max of boost, I would guess a 3.0 pulley? I wouldnt run the Meth injection either. When its time for a trans, then 2500 stall converter and 3.29 single chain gears
    Thank you for your business,
    Turbo Tim..... Thats what he says.. Whats your thoughts on this and why would I not wanna run a meth setup?? a 2.8 pulley?? My setup is gonna be a new block ( already have it and is ready for assembly) xpz cam package with the right pushrods. Bought the oem lifters, zzpcnc ported heads, 42# injectors,zzp 350 fuel pump, diamond pistons, L32 connecting rods, SSIC, SSAC headers,ported blower, ported LIM, ported TB, all new bearings, ARP main and head studs, I have evrything here listed already except the diamond pistons and ARP studs.. what do you guys think ?
    STOLEN XPZ SETUP WITH CNC PORTED HEADS!!
    13.76@99.60 on 3.4 setup
  2. #2 Re: XPZ SETUP....and zzps thoughts
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    nevermind.
    Last edited by noreasonwhyy; 07-30-2010 at 05:20 PM. Reason: didn't read the whole post.
  1. Tire thoughts.
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 08-03-2015, 12:21 AM
  2. What are your thoughts on SLP
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-11-2009, 02:07 PM
  3. thoughts
    By 99gpse in forum Off Topic Discussion
    Last Post: 02-23-2009, 02:34 AM
  4. thoughts on headlights
    By 99gpse in forum General Tech Discussion
    Last Post: 12-19-2008, 01:03 AM
  5. Well I Need Some Thoughts...
    By SlickGTP in forum Off Topic Discussion
    Last Post: 01-14-2008, 01:28 AM
