Thread: 99 GTP Rear humming noise
Results 1 to 5 of 5
  1. #1 99 GTP Rear humming noise
    SE Level Member Cbierniat24's Avatar
    Mi
    I recently replaced studs on my rear hubs and now there is a humming noise above 35 mph. Could it be the studs not being seated properly cause this or bad hub from overkill with my best friend hank the hammer?
  2. #2 Re: 99 GTP Rear humming noise
  3. #3 Re: 99 GTP Rear humming noise
    SE Level Member timmysgtp's Avatar
    Jul 2010
    marrero louisiana
    jack up car and grab top and bott of the tire and try 2 wiggle it from front 2 back. If it has play in it then the bearings ar bad
  4. #4 Re: 99 GTP Rear humming noise
    Mi
    No play with either tire. I've also had an alignment done recently.
    This is extremely annoying
    Tire somehow came out of balance? Warped rear rotors?
  5. #5 Re: 99 GTP Rear humming noise
    Jul 2010
    marrero louisiana
    maybe is tires out of balance unless its the susp.
  1. humming noise
    By speed24 in forum General Tech Discussion
    Last Post: 07-01-2010, 02:25 PM
  2. Humming noise from rear of car
    By jokyfo in forum Tires & Wheels
    Last Post: 06-04-2010, 01:36 PM
  3. Loud Humming noise... What is it?
    By brownb66 in forum General Tech Discussion
    Last Post: 05-14-2010, 10:24 AM
  4. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  5. new humming noise??!!??!!
    By Morris 04 GTP in forum Brakes/Suspension/Chassis
    Last Post: 02-14-2009, 09:33 AM
